Old 03-11-2012, 10:41 AM   #1
Munstermotorsport
Member#: 313126
Question P1091 code: Tumble motors changed but still getting engine light.
Got a p1091 code and changed both valve motors. Engine light still comming on and I tried disconnecting the battery but still have the warning light. it now has gone into limp mode. Having problems with the tumble valves from day one. I use the car as a safety car for rallies. Under pressure now as the car is booked for a rally next weekend and need to solve this problem. Can anyone please help?
Munstermotorsport is offline   Reply With Quote
Old 03-11-2012, 07:39 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
well...first of all...you didnt even tell us what kinda of car you are having issues with
and you didnt say if there were any other codes
and you DID know those tgv's are spring loaded and you have to install the motors properly or they wont work right
and it seems you didnt do much research on this
Click to View Search Results for p1091 - Google Search p1091 - Google Search
Old 03-11-2012, 09:31 PM   #3
Munstermotorsport
Member#: 313126
The car is 01 WRX, no other codes. You may be right with the spring loaded, this has come to mind but could not find any instructions on how to fit them, should the motor be fitted with the spring loaded or unloaded? In other words when the motor is taken out I can hear the valve springing back,do I need to refit the motor with it in that position or does it need to be opened before mounting the motor? If so how is this done?
Old 03-11-2012, 10:56 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
the motor needs to be attached and rotated to produce the proper pre-load on the shaft
Old 03-12-2012, 04:02 PM   #5
Munstermotorsport
Member#: 313126
We tried setting the valves up today by rotating 90 degrees, but no luck or improvement. As much as I hate to say it, I think we will have to give in and send it to the main dealer. Disappointing to say the least.
Old 03-12-2012, 08:28 PM   #6
Munstermotorsport
Member#: 313126
Thanks for taking the time to help, Uncle Scotty. When I find out what is wrong I'll post it here.
Seamen Demon, gets his head cutoff but still gets a hand on it... (CW's Reaper) Kostamojen Off-Topic 18 05-01-2008 10:59 PM
Taken motor apart, but still can't figure out why #4 went out ... (pics) jefersun Texas Impreza Club Forum -- TXIC 17 07-20-2005 03:01 PM
Taken motor apart, but still can't figure out why #4 went out ... (pics) jefersun Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 07-20-2005 12:49 PM
3.3 OHM resistor, but still have airbag light! cronic Electrical & Lighting 8 08-28-2004 12:31 PM
