Welcome to the North American Subaru Impreza Owners Club Wednesday April 23, 2014
Old 03-11-2012, 11:05 AM   #1
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Default cam gears "jumping"
I am trying to align all of my pulleys (after removing heads) to the proper position for installing the timing belt. My cam gears just kind of "pop" into place. I try to spin them, and I can get maybe 1/8th of a turn, then they pop back to where they were, which is about where the line on the pulley is 1/8th of a turn PAST the line on the head. Any suggestions?
tenchu is offline   Reply With Quote
Old 03-11-2012, 12:50 PM   #2
leecea
Member#: 37359
2003 WRX
You have a different engine, so not sure if the same thing applies, but the driver side cam gears will not stay aligned due to valve spring pressure. Search for Meaty's timing belt thread and it will explain all the details. Also, it is important to rotate these pulleys in the correct direction. That thread has a diagram showing how to do it. You'll need a small breaker bar and 10mm hex key socket.
leecea is offline   Reply With Quote
Old 03-11-2012, 01:18 PM   #3
Rally Monkey
Member#: 36310
03 WRX Sedan
Tools that can help subaru.spx.com Part#'s 499207300 and J-42908.
Rally Monkey is offline   Reply With Quote
Old 03-11-2012, 02:08 PM   #4
tenchu
Member#: 64147
1993 STi RA V LTD
Green
That's the cam im speaking of leecea. I'll look that up, thanks
Old 03-12-2012, 08:02 AM   #5
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
or some spring clamps to hold the belt to the cams while you get it all set up
FS: EJ205 WRX driver's side lower cam gear and cam gear/timing belt cover gling Engine/Power/Exhaust 5 11-11-2010 07:25 AM
FS: EJ205 WRX driver's side lower cam gear and cam gear/timing belt cover gling Tri-State Area Private Classifieds 5 08-21-2009 08:39 PM
FS: EJ205 WRX driver's side lower cam gear and cam gear/timing belt cover gling NESIC Private Classifieds 5 03-17-2009 01:19 PM
avcs cam gears, and exhaust cam gears. starace Engine/Power/Exhaust 3 06-11-2008 12:21 PM
Custom cam gears for USDM WRX heads running on a 7 tooth cam gear. Brydon Subaru Conversions 2 05-01-2007 08:19 PM
