Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 03-11-2012, 05:06 PM   #1
SubaruWRXtreme
Member#: 307112
2009 WRX (hatch)
Satin White Pearl
Default CEL light with P0171 and P0102
Hi guys couple of weeks ago I installed my cat back system on my 2009 WRX hatch and drove for a few weeks without any issues enjoying the sound of the exhaust. But lately the CEL came on and I scanned it and I got P0171 (System Too Lean) and P0102 (Mass or Volume Air Flow Circuit Low Input) then of course i cleared it but i comes back on after a few days then i decided to clean the MAF sensor and it was indeed dirty. After that little fix the car was driving much better and MPG- went up but guess what.... the CEL came back on anyway. The car drives just fine only at idle it fluctuates a little bit and i mean 100-200rpm you barely notice it.
But I'm all out of ideas, I'm starting to think that one of the 02 sensor is shot or MAF sensor is not working properly and triggering the CEL.
SubaruWRXtreme is offline   Reply With Quote
Old 03-17-2012, 02:38 PM   #2
SubaruWRXtreme
Member#: 307112
2009 WRX (hatch)
Satin White Pearl
Anyone ?? LOL
Old 03-17-2012, 06:28 PM   #3
jlmillionaire
Member#: 292740
2004 sti
qrb/cf frnt cf rear bmp
I just threw a p0011 avcs can anyone help me with that?
jlmillionaire is offline   Reply With Quote
Old 03-17-2012, 06:53 PM   #4
SubaruWRXtreme
Member#: 307112
2009 WRX (hatch)
Satin White Pearl
Your camgears-belt might might have skipped a teeth or two, have it checked quick !!
Old 04-04-2012, 10:45 AM   #5
SubaruWRXtreme
Member#: 307112
2009 WRX (hatch)
Satin White Pearl
Ok what helped solve my CEL P0171 and P0102 was just cleaning the MAF sensor, i used non-chlorinated brake cleaner always make sure it's non-chlorinated and sprayed both the temp sensors and MAF sensor wires. Did a tune up and cleared the CEL, it only showed the history of the CEL and that it was not the current CEL so i cleared it and all is well for 3 weeks now !!
Old 04-07-2012, 06:04 PM   #6
BGPKR
Member#: 41842
2006 LGT LTD 5SM
I've been getting the same code on my LGT. I've cleaned the maf and it came back the next day. I'm thinking it's possibly the 02 sensor. Possible?
BGPKR is offline   Reply With Quote
Old 04-07-2012, 07:32 PM   #7
SubaruWRXtreme
Member#: 307112
2009 WRX (hatch)
Satin White Pearl
It could be man, is the car idling fine or badly ??
My case I was worried it was the 02 sensor but the car idled just fine and drove just fine only the CEL came on. I reseted it and it came back then I decided to clean the MAF sensor with brake cleaner (non chlorinated) and gave the car a big tuneup changing oil and all the filters especially the fuel filter it might have been clogged and then reseted the CEL. Never came back on, I was worried because 2 weeks before I installed a CBE and the CEL I thought to myself damnit this can't be I didn't even touch the 02 or CAT.
If the car is idling rough or has bad performance and wasting gas it's probably the 02 alright.
Old 02-19-2013, 02:10 PM   #8
Brandong
Member#: 331008
2008 WRX
Red
. I originally had a p0174 which is o2 sensor . I replaced the o2 sensor last month and it ran like brand new. 3 weeks later I got another cel, p0171. so I erased it. the code pops up about once a day now and I just erase the code. The only mod i have currently is Cobb sf intake, with access port running stage 1 91 octane stock map. I idle at around 1000RPMs. I've checked all my vacuum lines for leaks, cleaned my sensor with breaker cleaner, but can't find any problems with it. I can't see it being a o2 sensor again. But my car shakes like it is and the mileage is normal. Any ideas guys?
Brandong is offline   Reply With Quote
CEL light coming on and off 06cgmwrx Newbies & FAQs 1 10-05-2010 02:47 PM
CEL Light with a Injen CAI? xtreme_hack AccessPort 19 04-21-2006 08:35 PM
CEL lights keeps comin and goin... CyCoFooKee Factory 2.0L Turbo Powertrain 5 10-21-2004 03:17 PM
cel light with clutch/flywheel upgrade? advfit Transmission (AT/MT) & Driveline 6 06-04-2004 04:01 PM
CEL light with CAI, HELP! IMI North West Impreza Club Forum -- NWIC 8 04-13-2002 10:47 AM
Message Board Statistics All times are GMT -4. The time now is 03:04 AM.
