Old 03-12-2012, 01:54 AM   #1
kyky489
Member#: 253266
2011 STI
Default 2011 WRX Data logs...Stage 2 + AEM intake = CEL?
I recently installed an AVO down pipe on my 2011 wrx and flashed to the stage 2 + aem intake normal wastegate. Those are my only mods as far as the engine...i drove for a couple days and then i got a cel with the code p2096, which is post catalyst fuel trim system too lean bank 1. I cleared the code and made sure both my real time maps and reflash are the same. I would appreciate any feedback and advice on my data logs and as to why i keep getting the code? Im in oregon running the 91 octane map but putting 92 in my car. after i clear the code, It seems to pop up again after about 30 miles of driving...
I took this data log the other night right after clearing the code (resetting the ecu)
https://docs.google.com/spreadsheet/...ZQ2RMTlE#gid=0
Then i just took this one tonight after driving all day without resetting the ecu...
https://docs.google.com/spreadsheet/...VMxWm9CUFBYV0E
kyky489 is offline   Reply With Quote
Old 03-12-2012, 01:46 PM   #2
Airboy
Member#: 72829
2006 WRX
2015 WRX
Could be an exhaust leak between the downpipe and the cat-back exhaust.
Airboy is online now   Reply With Quote
Old 03-12-2012, 02:00 PM   #3
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Did you correctly reinstall the rear O2 sensor? It sounds like it got damaged or is unplugged or something similar.
lancelucas is offline   Reply With Quote
Old 03-12-2012, 02:12 PM   #4
kyky489
Member#: 253266
2011 STI
I thought about that but the o2 sensor is before that connection so anything happening there I would think wouldn't affect it? I can still try to see, how would I go about checking to see if it is leaking?
As far as I know, I did. I will have to double check but it's pretty straight forward. All I did was unscrew it out of the stock downpipe and screw it into the AVO pipe. Then plugged it back in after I got the down pipe in place. The wires did get twisted a little before I realized I needed to take off the heat shield and all that but it was really minor...but i guess there's a chance they got messed up?
Old 03-25-2012, 09:09 PM   #5
kyky489
Member#: 253266
2011 STI
Took this data log last night, temperature was 45 degrees. Can someone just look it over and let me know how it looks?
https://docs.google.com/spreadsheet/...xWE5kdEE#gid=0
Thanks!
Old 03-26-2012, 09:34 AM   #6
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
you seem to be slightly underboosting. you're only hitting 16.68psi, should be higher for stage 2. I'm at stage 1 + Cobb intake and i'm at around 16.5 or so peak on the normal waste gate map. which waste gate map are you running?
subiebosch is offline   Reply With Quote
Old 03-26-2012, 03:38 PM   #7
kyky489
Member#: 253266
2011 STI
I'm running the normal waste gate map. When I was stage 1 + AEM I ran the high waste gate cause I live at a low elevation I think. I'm wondering if I have some sort of exhaust leak and that could be causing the check engine light?
Stage 2 SF Intake Log orijinalx AccessPort 8 10-10-2012 08:43 AM
2012 data log stage 1 questions hutch959 AccessPort 4 03-13-2012 09:53 PM
2011 WRX Stock vs. Stage 1 vs. Stage 2 xluben Proven Power Bragging 34 02-15-2012 08:01 AM
2011 wrx data log :( mdsubie11 AccessPort 7 08-22-2011 09:38 PM
2011 Subaru STI stage 2 plus intake. Before/After intake test. Innovative Tuning Proven Power Bragging 25 01-08-2011 09:13 PM
