Old 03-12-2012, 03:39 AM   #1
tairyhesticles
Member#: 311614
1995 WRX
Default USDM Transmission for GC8 WRX
I am looking at replacing / updating the transmission in my 1995 WRX, mine is starting to make whining noises in 1st and 4th.
My question is, has anyone replaced their GC8 WRX transmission with something a little newer, and liked it? I am talking mostly about an 04+ transmission, since i've heard they were updated with wider gears to fix the older "glassbox" problems. (Can anyone confirm this?)
Also with a newer transmission, does the rear differential need to be swapped simultaneously, or will the GC8 differential be compatible?
Thanks for your help, NASIOC!
tairyhesticles is offline   Reply With Quote
Old 03-12-2012, 06:51 AM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
rear diff follows the tran's final drive
the short gears really complement the G. Long 3.90 usdm are going to be noticably slower from 0-100.
eg33GC is offline   Reply With Quote
Old 03-12-2012, 08:43 AM   #3
tairyhesticles
Member#: 311614
1995 WRX
Right on. So what would I replace it with if I wanted to get shorter gears? just another GC8 transmission? Or is there some other transmission that's "optimal"? I've heard people raving about the GC8 RA transmission.
Old 03-13-2012, 03:09 AM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I vote for using a 98-01RS transmission with 4.11 final drive. The shorter final drive gives great acceleration and since the mechanical advantage is better you are less likely to break gear teeth. The only "issue" is that it is an NA style clutch so you'd need a new slave cylinder (and possibly master if you don't like the ratio)
You can also find the same transmission in some Forester and Outback. I have one for sale but its in California.
Old 03-13-2012, 09:19 AM   #5
tairyhesticles
Member#: 311614
1995 WRX
I actually have one of those transmissions available to me, friend is parting out an 01 forester. How many km on your transmission for sale? Maybe PM me with details and price.
Old 03-13-2012, 01:41 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
I think the 01 forester also has the same transmission. It has just under 200,000 kilometers. Never really thought of a price but I am open to offers. I might have the matching clutch parts as well? Ill look
JDM vs USDM downpipe for 2008+ WRX olie92 Newbies & FAQs 7 12-24-2011 12:44 PM
WTB : Looking for a transmission for 02 WRX pnoyjstylez Tri-State Area Private Classifieds 4 12-08-2010 05:13 PM
cobb AP USDM Ok for Canadian wrx 265? funkyhunky Engine Management & Tuning 0 09-26-2009 06:17 PM
JDM Pink vs USDM Pink for 05 WRX Kenji815 Brakes, Steering & Suspension 16 10-13-2004 04:32 PM
Replacement transmission for the WRX? Strepto Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 03-25-2001 12:59 AM
