Old 03-12-2012, 08:00 AM   #1
steveomiami
Member#: 309883
Default Updated running issues thread......
Its a 1992 JDM wrx with a z4(or is it z6) ecu......(the 260 hp one) The car has the stock intercooler, i just put a MBC in place of the stock unit, It has 3 inch turbo back exhaust I don't think it has a cat, it appears to have stock injectors, it has an apexi intake. Currently its running with the MAF plugged in and it has a rough idle around 1000 rpm sometimes surging up and down a little bit. If I unplug the Maf it will idle around 1500-2000 rpms. If I unplug the MAF while the car is running it dies. The ICV appears to have a little damage to it because there are little magnetic bits floating around in there. When driving it feels gutless/little power like its surging back and forth and holding back. If I try to take off i can hear the turbo spool and my aftermarket gauge hits about 7 psi with the car pulling some then bam it hits a wall before it even hits 4000 rpm. The first time it had a big puff of black smoke. The car does not smoke normally. I'm thinking fuel pump or clogged filter maybe. This car is new to me and i am new to turbo cars so i am new to the sounds but it also seems like the BOV releases air when shifting when I'm not under boost yet
steveomiami is offline   Reply With Quote
Old 03-12-2012, 08:52 AM   #2
tairyhesticles
Member#: 311614
1995 WRX
Did all of these problems arise when you put the MBC on, or were they pre-existing? When a Bov leaks, it is letting out air that the MAF has already accounted for. it will put in X amount of fuel for the X amount of air it read coming in.
If the Air/Fuel ratio is too low, then your car will run rich and shoot black smoke, sometimes flames too (especially if you say it's catless). Your BOV is opened and closed by boost pressure/ vacuum, so check your vacuum lines for any leaks. Also check your I/C and charge piping for any holes.
That's my .02 anyway.
tairyhesticles is offline   Reply With Quote
Old 03-12-2012, 10:11 AM   #3
steveomiami
Member#: 309883
I bought someone else's problem for a good deal so the problems are pre existing. how can I test my BOV?
Old 03-12-2012, 11:31 AM   #4
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Do you have any gauges installed that might further tell you whats going on?
Check and possibly replace all of the vaccuum hoses you rerouted when installing the MBC.
Boost/vacuum gauge is vital if your using an MBC. What is your max boost. Right now? Do you have any extra hoses that are unaccounted for (hanging unplugged and loose)?
Is it possible you've reversed a hose or that something that was already worn out is suddenly causing you an issue since its been connected to the MBC.
Also have you tried adjusting your idle up a bit by rotating the IACV? Did your problems start after you installed the MBC or after you opened up the IACV?
TommyAtomic is offline   Reply With Quote
Old 03-12-2012, 11:44 AM   #5
steveomiami
Member#: 309883
I have a boost/vacuum guage, The MBC is set very low its a voodoo 3 with ceramic ball bearing. I disconnected the one on the strut, unhooked the electric plug and hooked the one from the turbo on the bottom of the voodoo(input) and the one from the top of the voodoo to the wastegate. If I let it boost it goes up to about 7 psi. There are no hanging or loose vacuum hoses. i have been looking for leaking ones but found none yet. The car had the problem when i bought it already. It also had 2 bad coils that i replaced, maybe theres a third one going out but i don't think that would cause that instant cutoff that I'm feeling. I already did a compression test and that was good. I have been playing with the iacv but does that affect anything while under throttle?
Old 03-12-2012, 11:49 AM   #6
dirtslayer
Member#: 242550
2002 impreza wrx wag
olive drab
What's your idle vaccum? Seems like a pre turbo leak. the ecu would be attempting to account for unmetered air if u have a leak possibly causing the smoke
dirtslayer is offline   Reply With Quote
Old 03-12-2012, 11:56 AM   #7
steveomiami
Member#: 309883
Its idling pretty rough but i just checked it and its 12 lbs vacuum.
Old 03-12-2012, 12:02 PM   #8
dirtslayer
Member#: 242550
olive drab
Def have a leak. Get some starting fluid spray and spray down all vac hoses/components/ basically anything after maf oring to the heads
Old 03-12-2012, 12:10 PM   #9
steveomiami
Member#: 309883
what should the reading be? what will the starting fluid spray do
Old 03-12-2012, 12:12 PM   #10
dirtslayer
Member#: 242550
olive drab
Oh boy, good luck.
Ok, a decent running engine idle vac without having race cams should be around 18-21hg. If lower something is leaking.
And the spray is highly burnable by the motor, so when a vac leak is present it will suck in the spray and idle up
Old 03-12-2012, 12:17 PM   #11
steveomiami
Member#: 309883
yeah i figured out the ether thing right after i sent the mail haha never used that trick
Old 03-12-2012, 12:18 PM   #12
tairyhesticles
Member#: 311614
1995 WRX
Originally Posted by dirtslayer View Post
Oh boy, good luck.
This guy's got it right. Low vacuum and low boost definately = vacuum leak. Even with the mbc on, you are running lower than stock boost. Good luck with your new nightmare! happy searching!
Old 03-12-2012, 12:21 PM   #13
tairyhesticles
Member#: 311614
1995 WRX
And if you want to check for a leak in your charge piping/ bov, look into a boost leak tester. You can make your own for about $10 with an air pump and some plumbing fittings from a local hardware store.
Old 03-12-2012, 12:39 PM   #14
steveomiami
Member#: 309883
The boost is low because i set it low i havn't tuned it at all yet....now off to find that vacuum leak i hope you are all right
Old 03-12-2012, 12:53 PM   #15
dirtslayer
Member#: 242550
olive drab
Let's make a bet. If I'm right and its a leak you gift me the jdm wrx and if I'm wrong ill paypal a dollar to you
Old 03-12-2012, 01:01 PM   #16
steveomiami
Member#: 309883
haha good try
Old 03-12-2012, 01:19 PM   #17
dirtslayer
Member#: 242550
olive drab
Go fix it, I wanna know! And btw if ya dnt mind, how much did u get it for?
Old 03-12-2012, 01:28 PM   #18
steveomiami
Member#: 309883
i got it for 1400 because of the issues its having and it was overheating a little(thermostat was stuck) I stole it!!!!!!!!
Old 03-12-2012, 01:29 PM   #19
dirtslayer
Member#: 242550
olive drab
Pics now needed
Old 03-12-2012, 01:37 PM   #20
tairyhesticles
Member#: 311614
1995 WRX
1400 is a steal, a rolling shell is worth that much! Agreed, let's see some pictures.
Old 03-12-2012, 06:15 PM   #21
steveomiami
Member#: 309883
Is the cat in the up pipe? Could a stopped up cat cause these symptoms?
Old 03-12-2012, 06:40 PM   #22
tairyhesticles
Member#: 311614
1995 WRX
All pre 2002 wrx's come factory with a catless uppipe. And your symptoms don't match those of a plugged catalytic converter.
Old 03-13-2012, 02:38 AM   #23
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Oh boy, good luck.
The amount of Vac your gauge is reading is low very likely something is leaking. But what it reads will really depend on what your idle RPM is set to.
What RPM are you Idling at?
Old 03-13-2012, 05:37 AM   #24
steveomiami
Member#: 309883
I think that reading was taken around 1000 rpm
Old 03-13-2012, 10:21 AM   #25
dirtslayer
Member#: 242550
olive drab
That's low still
AEM EMS update, file issue FQ06 Other Engine Management 4 06-28-2011 12:28 PM
having vacuum/lean run issue...need advice/input Homemade WRX Factory 2.0L Turbo Powertrain 15 06-08-2004 07:21 PM
Should I stop updating the CSC thread? AcquaCow Off-Topic 19 04-13-2004 07:28 PM
Message Board Statistics All times are GMT -4. The time now is 05:02 PM.
