Old 03-12-2012, 08:05 AM   #1
megabyte5689
Member#: 313179
Default alternator belt tension?
What's the best way to tell if you have the right tension on your alternator belt? I replaced my belt 4 months ago and made a tick mark off to the side to annotate where the old belt tension was that way I didn't have to mess with it. Well when I put on the new dayco belt and tightened it up to that mark that I made it seemed a little tight so I loosened it down. I took my car into the shop a couple of days ago to get an oil change and they said the belt was kind of squealing, so they adjusted it for me, and they brought the tension up to the sharpie mark i made. How can I tell if it has the 1/4'' of play in it? It feels a little tight. do i push up and down on the top or on the side?
megabyte5689 is offline   Reply With Quote
Old 03-12-2012, 10:02 AM   #2
jays05
Member#: 78165
05 STI 35r + e85
I have always tightened it until I can twist the belt 90 degrees at it's longest stretch.
jays05 is offline   Reply With Quote
Old 03-12-2012, 10:06 AM   #3
leecea
Member#: 37359
2003 WRX
Not sure if this is the correct way, but I did the folllowing:
- Find the middle of the longest run between pulleys
- Hold a small ruler against the belt with one hand
- Push the belt in with the other hand and see if it deflects by 1/4"
The hardest part is keeping the ruler fixed while pushing on the belt. I braced my ruler-hand against something solid.
leecea is offline   Reply With Quote
Old 03-13-2012, 11:48 PM   #4
Vrooom_Psh
Member#: 311923
04 STi
i tighten just until you can't twist the belt 90 degrees. there are also belt tension gauges available!
Vrooom_Psh is offline   Reply With Quote
Alternator Belt Tension Block SausageOfPower Service & Maintenance 2 02-20-2010 07:27 PM
Need Alternator Belt Tensioning Bolt spec rage557 Normally Aspirated Powertrain 2 12-19-2008 01:03 PM
alternator belt tensioner broke SilverSpool Texas Impreza Club Forum -- TXIC 4 01-04-2007 10:58 AM
Need A/C and Alternator belt tension torque specs Shaitiger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-19-2004 11:59 PM
picture of alternator belt tensioner WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-06-2002 03:29 PM
