Old 03-12-2012, 04:02 PM   #1
SomeCanadianGuy
Member#: 309969
2004 Impreza WRX STI
Java Black
Default JDM into USDM
I have an '04 STi with a blown usdm engine and have found a jdm ej20 version 8 engine. Is this compatible with my car and are there any tuning issues, harness issues or other issues to worry about? Thanks for the help!
SomeCanadianGuy is offline   Reply With Quote
Old 03-12-2012, 04:39 PM   #2
SomeCanadianGuy
Member#: 309969
Java Black
PS this comes with the entire setup including turbo, intercooler, ECU etc.
Old 03-12-2012, 06:17 PM   #3
SomeCanadianGuy
Member#: 309969
Java Black
Oh and the engine is '04 as well if that helps. I've been told
It will spool slower but it shouldn't be a big issue
Other than that. Is this true? I appreciate anyone's input!
Old 03-12-2012, 06:45 PM   #4
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
I think you could do it if it comes with the wiring harness also. I dont think your wiring harness is compatible. The throttle body on the sti is dbw and on the wrx its dbc, I dunno if the jdm sti has dbw or dbc.
Your gonna have to search that up.
TDagen is offline   Reply With Quote
Old 03-12-2012, 07:07 PM   #5
atomicfire
Member#: 136296
2005 STi
I applaud you for your thinking, but it's likely that the work will be a lot more trouble than what you're welling to get yourself into.
What exactly is blown in the USDM engine? If you can get the engine removed and installed on your own, you can often get the engine rebuilt with forged internals for a decent price.
atomicfire is offline   Reply With Quote
Old 03-12-2012, 08:40 PM   #6
SomeCanadianGuy
Member#: 309969
Java Black
Well before I took it out it came up with two error codes for the cams and the number 4 injector is toast i've been told by my mechanic. The engine is out and apart ($1300 because I have no time to do it all myself) and the pistons and bearings were pretty much toast on it as well (surprise surprise...) what trouble would I run into? I have it all set up for stage two so the decision is to rebuild it to handle the 400hp/23psi its set up for or find a stock longblock and go back to stock and sell the curse of a thing...
Old 03-12-2012, 09:46 PM   #7
kayen
Member#: 57287
2002 Bugeye STi
MY03 Fozzy XS
You have a lot of wiring ahead of you, if you ever plan to go from a 32 bit ECU EJ257 to a 16 bit ECU EJ207. You pretty much have to rewire your entire car to make this work. This is not a cheap solution and from what I have read in this thread it's not something you want to dabble in.
Find a used EJ257 or a new Short Block. Also might be a good idea to find out what parts are bad. Saying you have CEL codes for Cams doesn't say much at this point. If your Heads are still good, you can maybe get away with a new Short block, clean the heads and have a fully working STI again.
kayen is offline   Reply With Quote
Old 03-14-2012, 05:34 PM   #8
CatfaceType-R
Member#: 81102
If u want that motor you have to do some work, google iWire for the wiring services, your mechanic will pull your harness and send iWire your sti harness and the purchased jdm engine harness and jdm ecu for a marriage; have mechanic install v8 motor and do all that jaz, install modded harness and go. I think this is correct, feel free to comment as I don't remember, but i think it's that simple;
if you call that simple.
CatfaceType-R is offline   Reply With Quote
JDM STI EJ207 version 6 into USDM 02 wrx hELP!!! drftwell Subaru Conversions 6 07-31-2008 02:10 AM
JDM HID kit into USDM bugeyes......possible? legacyvt286 Interior & Exterior Modification 0 10-07-2006 12:23 AM
JDM sti into USDM 2001 2.5rs HELP! K6DimE Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-23-2006 09:42 AM
Early JDM EJ20G into USDM EJ22 Legacy 96WRX Subaru Conversions 2 09-10-2004 01:54 PM
Fitting JDM Foglights into USDM Bumper chaddeus Interior & Exterior Modification 5 04-07-2004 12:14 AM
