Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Closed Thread
Old 03-12-2012, 05:14 PM   #1
milly238
Member#: 297801
Default Thinking about buying a sti and need some advice!
Hey everyone, I hope i can get some help help or insight. I am looking at a 2007 WRX STI and it only has 23,000 miles.
The dealer ship guy told me the reason it's throwing the CEL and codes is because the other guy had some modifications like a intake etc and when he went to sell it, he just took all the sensors and what not out..
He cranked the car up for me and it sounded great, engine idled for 5-10 minutes, no problem... Cold AC etc.
I asked if i could see the codes on the code reader. We hooked it up and 18 codes came back. They are:
Code: P0458
Description: Evaporative emission (EVAP) system, EVAP valve - circuit low
Specification: Wiring short to earth, EVAP valve
Code: P2016
Description: Intake manifold air control actuator position sensor/switch, bank 1
- circuit low
Specification: Wiring short to earth, intake manifold air control actuator
Code: P2021
Description: Intake manifold air control actuator position sensor/switch, bank 2
- circuit low
Code: P2008
Description: Intake manifold air control actuator, bank 1 - open circuit
Specification: Wiring open circuit, intake manifold air control actuator
Code: P2011
Description: Intake manifold air control actuator, bank 2 - open circuit
Code: P2431
Description: Secondary air injection (AIR) system, air flow/pressure sensor,
bank 1 - range/performance problem
Specification: Wiring, air flow/pressure sensor
Code: P2433
bank 1 - circuit high
Specification: Wiring short to positive, air flow/pressure sensor
Code: P0016
Description: Crankshaft position/camshaft position, bank 1 sensor A -
correlation
Specification: Wiring, CKP sensor, CMP sensor, mechanical fault
Code: P2021
- circuit low
Code: P2008
P20011
Code: P2431
Code: P2433
Code: P0016
correlation
Code: P2419
Description: Evaporative emission (EVAP) switching valve - circuit low
Specification: Wiring short to earth, EVAP switching valve
I just want to know if any of you guys could let me know anything about some of those codes as well as if it's worth buying..How much is it to fix some of those things? It seems they are all emission related. Maybe the cat has been removed?
Thanks everyone, have a nice day!
milly238 is offline
Old 03-12-2012, 05:29 PM   #2
b1aze
Member#: 284003
2010 Alpine 135i
Run. Fast.
b1aze is offline
Old 03-12-2012, 05:42 PM   #3
milly238
Member#: 297801
Originally Posted by b1aze View Post
Run. Fast.
Thanks for the response, you think i should? It looks like most of them are sensors though?
milly238 is offline
Old 03-12-2012, 05:45 PM   #4
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
depends how much you enjoy working/repairing cars. Personally, i havent dealt with these codes specifically, but I am tired of high maintenance myself.
I wouldnt even bother. who knows, it may be a simple fix, but i wouldnt want to risk it
07VTRex is offline
Old 03-12-2012, 05:47 PM   #5
milly238
Member#: 297801
I don't want to work on it much if any. I was planning to take it to the subaru dealership and see how much they would estimate to fix everything..
I wouldnt think it would be too much if it's just sensors? The car sounded great.
milly238 is offline
Old 03-12-2012, 05:53 PM   #6
RRPLGT22
Member#: 312471
2009 Legacy GT
If its all stock and he used to have it stage 2 ect, it could tuned for those mods and now is throwing codes because the stock parts are back on it and the ecu is still compensating for the intake, exhaust. Not positive, just a thought because I doubt he "took out all the sensors"
RRPLGT22 is offline
Old 03-12-2012, 06:03 PM   #7
milly238
Member#: 297801
It definitly makes since... Do you know what would be needed in order to get the codes off, or basically fix the car if it were due to stage 2?
Like i said, the motor ran for 10 minutes or so and sounded wonderful.
milly238 is offline
Old 03-12-2012, 06:26 PM   #8
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
http://forums.nasioc.com/forums/show....php?t=1679821
If you even THINK of buying this without a professional paid inspection, you are nuts.
Unabomber is offline
Closed Thread
Thinking of selling my 09 WRX need some advice Ron09 Mid Atlantic Impreza Club -- MAIC 24 10-15-2011 05:12 PM
Thinking about buying an STi, some opinions here? firebird400 General Community 32 12-10-2007 01:43 PM
Think my pilot bearing is tost..... Need some advice. ControlFreak North West Impreza Club Forum -- NWIC 7 05-15-2007 12:22 PM
I'm going to buy a WRX - need some advice on a dealer... tshah Bay Area Impreza Club Forum -- BAIC 25 07-30-2002 01:00 AM
