Old 03-12-2012, 07:56 PM   #1
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
Default 2002 Wrx P0301, P0303, P0335
P0335- it has happened twice, but I try to start my car, and the solenoid clicks, but no crank. I read it might be a bad batt connection, I will try that
P0301 & P0304- never had this problem before... always happens when I warm up my car. I start the engine, everything sounds find... and when i come back, the CEL is on. this happened last week too.
Car-2002 WRX with Cobb stage 1 AP2 OTS map.
any suggestions? was thinking of doing plugs this weekend.
cueballsi is offline   Reply With Quote
Old 05-12-2012, 11:04 AM   #2
itzmrchan
Member#: 150741
02 Wrx Sedan
im having the same problem with p0335.. its been going on for about a few months and some days I have to push start my car a few times in one day. other times it doesnt happen for weeks. I changed out the sensor but after 1 month it started happening again. plz lmk if you fix it so i can also thx
itzmrchan is offline   Reply With Quote
Old 10-31-2013, 03:13 AM   #3
Lowkey_Subie
Member#: 372325
Same here, been having same problems I've replaced my sensor more then 3 times and sometimes my car doesn't wanna turn on, all I hear is a click my check engine light code comes up then a little later goes away some other days comes back any clue?
Lowkey_Subie is offline   Reply With Quote
Old 10-31-2013, 10:04 AM   #4
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
301 and 304 are misfires.. whens the last time the car got plugs?
335 no clue...
p0301,p0303,p0304 at wits end tried everything!! 04stinugget Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 07-28-2012 12:06 PM
P0301 P0303 P0304...?? 04WRWRX Service & Maintenance 3 05-02-2011 01:54 PM
2002 Wrx P0301, P0304 codes TheHighestCrew Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-14-2010 08:10 PM
Misfiring... P0301 P0303... Plus missing coolant. poordna Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-14-2010 11:48 PM
Missfire Dtc P0301, P0303.p0304 yrlegacy Normally Aspirated Powertrain 8 08-28-2007 01:00 AM
