Old 03-12-2012, 08:20 PM   #1
Grieby54
Member#: 244643
2005 WRX Stage 2
CGM
Default 2005 WRX Air Conditioning Stopped Working
The title pretty well says it all. It's been winter up here in Colorado and I haven't had much need to use the A/C, but now that it's warming up it doesn't seem to be working. I grabbed one of those charge systems from Auto Zone with the the gauge on it, dumped pretty much the entire can in there, and with the A/C on the gauge didn't climb much. However, when I turn the A/C off the pressure jumps up to ~45 psi (I know it should be around ~35 psi). After putting half a can in, it seemed to work just fine. Then, the next day (I filled it, parked it, and left it all night) it was back to not working. Used the rest of the can, and repeated. Still not working.
I checked the door that's behind the glove box and it appears to be working, so I'm not sure what to do. The air is still hot regardless of whether or not I have the A/C on or recirculation on. I have the climate control model. There is no belt squeal, no chirping when I turn the A/C on, or any of that.
Any thoughts would be appreciated.
Grieby54 is offline   Reply With Quote
Old 03-12-2012, 10:42 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The system has a leak, take it to a shop and have it diagnosed and repaired properly. Once the leak is repaired it will have to be evacuated with a vacuum pump and recharged to the correct pressures with manifold gauges.
Old 03-14-2012, 03:18 PM   #3
workinprogress
Member#: 310341
08 WRX Sedan
^ sums it up. With a leak that fast you probably had something hit the condenser or one of the lines and cause a serious seal leak. Some UV dye and light should find the location. Then you're probably looking at receiver/dryer and an evac/recharge.
workinprogress is offline   Reply With Quote
Old 03-28-2012, 10:45 AM   #4
Grieby54
Member#: 244643
2005 WRX Stage 2
CGM
Any idea how much this is going to cost me?
Old 03-28-2012, 04:47 PM   #5
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
We don't guess costs here as we have no way of knowing. My last AC leak was diagnosed for $0 because I brought in a box of Duncan Donuts for the shop. See what I mean?
Old 04-01-2012, 11:01 PM   #6
easterbran
Member#: 307359
'05 STi Stage II
Haha "Duncan" Donuts
easterbran is offline   Reply With Quote
Old 04-01-2012, 11:02 PM   #7
easterbran
Member#: 307359
'05 STi Stage II
Oh, and I've got the same issue as you. Winter just ended and AC is blowing nothing but hot air. Gonna take it to the dealer. 05 sti btw
Old 05-05-2012, 02:32 PM   #8
easterbran
Member#: 307359
'05 STi Stage II
My A/C is fixed... 2 O rings failed and had to be replaced.
Air conditioning wont work! ramrod Texas Impreza Club Forum -- TXIC 8 02-16-2010 04:10 PM
NJ: WRX air conditioning compressor Cosworth Private 'For Sale' Classifieds 5 09-26-2005 04:37 PM
'04 WRX Air Conditioning Not Working aearnhardt Warranty Issues & SOA Problems 4 05-19-2005 07:48 PM
Rear lights out... air condition not working?? Impreza2.5RSTi Normally Aspirated Powertrain 2 11-06-2002 10:23 AM
