Old 03-12-2012, 08:41 PM   #1
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Default Boomba Racing Fuel Rails Install Help
So I orderd the fuel rails today and I'm trying to figure out how to plumb everything that way I can get all my fittings and hoses.
Here is a diagram that I found and am wondering if this will work since I will be running a AEM FPR and wont be using the distribution block for the stock fpr that comes with the fuel rail kit.
Garrek11 is offline   Reply With Quote
Old 03-12-2012, 08:46 PM   #2
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
You could T the return so you have a single feed to the fpr.
wrxsubiemod is offline   Reply With Quote
Old 03-12-2012, 08:54 PM   #3
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Ok and what size hose would I use for the ??? feed line up there?
Old 03-12-2012, 09:00 PM   #4
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Are you going to run new lines straight from the pumps? Or just reuse the factory hard lines?
Stock id is 5/16. you could go bigger but it wouldn't do much if you were going to just reuse the factory hard lines.
Old 03-12-2012, 09:04 PM   #5
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Your talking about the hardlines from the pump the the firewall im guessing. So yes I will be keeping those the same for a while. Just using new hoses insed the engine bay.
How much hose you think I should purchase?
Old 03-12-2012, 09:27 PM   #6
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Go get some string and mock it up. I don't know your budget or what type of line you want. Stainless braided, AN fittings? Brass or stainless barbs and T's?
A good cheap hose should be a SAE J30R9. But really depends on what you want done
Old 03-12-2012, 09:30 PM   #7
Serkan
Member#: 180514
2004 Sti
haha that is my MS paint diagram.
I still don't know what size line i should put in feed line before the "T". Keep it -6an or add a -8an for that section only...
Serkan is offline   Reply With Quote
Old 03-12-2012, 09:33 PM   #8
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
how much hose did you end up needing roughly?^^^
Old 03-12-2012, 09:39 PM   #9
Serkan
Member#: 180514
2004 Sti
I didn't buy any hose. I had a great deal on an aeromotive FPR and the seller gave me his SS teflon lines and all AN fittings with it.
Buy more than what you would need. I would say at least 8ft, to be safe get 10ft.
The lines are $3.50 per ft here :
http://www.anfittingsdirect.com/inde...849cc037e20969
Old 03-12-2012, 09:42 PM   #10
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Just checked how my perrin v1 are and it uses about 11 feet. look them up and you'll have a good idea of what they look like. That would be with new line to the fire wall hard lines
Old 03-15-2012, 08:15 PM   #11
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Which one is the return and the supply on the fuel rails themselves. Cuz in the picture above they are parrallel but the actual product they arent. One runs ontop of the other.
Old 03-15-2012, 08:40 PM   #12
No Limit Motorsport
Member#: 131945
2013 BRZ
Gunmetal
It doesn't matter, but I would think the feed in the top and the return out the bottom would be cleaner and make more sense
No Limit Motorsport is offline   Reply With Quote
Old 03-15-2012, 08:58 PM   #13
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Thanks you.
Old 03-16-2012, 09:00 PM   #14
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Well I got everything put on however the fuel injector wiring clips don't fit on because the fuel rails are in the way. And to top it off I can't fit the front injectors in because the cam sensor is in the way
Old 03-16-2012, 10:48 PM   #15
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
You can't turn the injectors? Pics would help
Old 03-16-2012, 11:38 PM   #16
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Nope you can turn them about 25 to 30 degrees but it's not enough to make a diff. In just gonna hardwire them in with heat shrink and everything.
Old 03-19-2012, 11:43 AM   #17
Hold_Fast
Member#: 175837
#61 9.5% FP
I had to clip off two small pieces of plastic on the injector wiring clips to make them fit under the Boomba rail. Other than that, I had no issues with the clips fitting.
Hold_Fast is online now   Reply With Quote
Old 03-19-2012, 12:11 PM   #18
Maxwell Power
Member#: 190729
I prefer series...
Less hose, less clutter, less misfires, less vapor pockets.
Maxwell Power is offline   Reply With Quote
Old 03-19-2012, 01:37 PM   #19
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Interesting.
Old 05-22-2012, 11:54 PM   #20
jtrakel
Member#: 242647
Bringing this thread back to life I'm looking at this amazing photo that was drawn for the OP and Im going to do it myself but with Perrin Top feed rails. How did this set-up work out for you and did it really matter which one is feed and which one is return?? I have a AEM FPR that I'm installing it also has 2 pressure ports (or inlet) and then one out thanks anything will help
jtrakel is offline   Reply With Quote
Old 05-23-2012, 12:54 AM   #21
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
Didnt matter we tried both ways and it worked the same either way.
Old 05-23-2012, 01:13 AM   #22
jtrakel
Member#: 242647
Awesome thanks I'm guessing the Perrin rails are the same my friend has boomba rails they looks pretty identical
Old 05-23-2012, 09:16 AM   #23
Serkan
Member#: 180514
2004 Sti
Originally Posted by Maxwell Power View Post
I prefer series...
Dom I keep seeing you saying series is better than running parallel. You should give us more insight in this topic.
Why would parallel lines cause misfires, vapor pockets ?
Thanks
Old 05-23-2012, 10:39 AM   #24
shwoop_soobie
Member#: 102323
99 power poles
beware
I run my fuel system just like this and its been working great..
But i would also like to know more about setting up series rather than parallel.
shwoop_soobie is offline   Reply With Quote
Old 05-23-2012, 11:01 AM   #25
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
There are a bunch of arguments to both sides however I have yet to see good enough proof to persuade me that series is better then parallel or parallel is better then series. I have yet to see a diff in performance between the two.
Boomba Racing Fuel Rail VS OEM Fuel Rail BOOMBA RACING Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 14 10-26-2014 01:34 PM
FS : SOLD SOLD new black boomba racing fuel rail kit, new crucial racing thermostat 160* fastwrx25 Engine/Power/Exhaust 12 01-18-2011 11:15 AM
Boomba Racing Fuel Rail BOOMBA RACING Engine/Power/Exhaust 1 01-20-2005 10:00 PM
Fuel Rail Install Help PGM Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 02-06-2004 02:18 PM
Fuel Rail Install Help Subaru300hpWRX Newbies & FAQs 3 12-09-2003 04:34 PM
