Old 03-12-2012, 11:07 PM   #1
SLegacy99
Member#: 117504
1999 Legacy Lmtd 5MT
Red
Default Need Some Post HG Replacement Help
So the HG job on my '99 Legacy GT was my first engine pull...and my second! However, I did it with some friends who have a lot more experience with cars than I do. Not Subaru experts however. So I could use some thoughts.
My problem is ticking. Which sounds like it is coming from cylinder number 2. We replaced both head gaskets of course, as well as having the heads machined by a fellow who claimed that he knew Subarus pretty well. Having taken apart the engine again we still have not been able to find the source of the ticking. This ticking actually sounds like the tick of a DI engine, but much louder. The engine runs better than ever however.
We originally thought that maybe it was a shim, but after looking at all of them, they all measured to spec. My roommate suggested that perhaps a blocked oil channel was the problem and used compressed air to clear any debris. Nada.
Any thoughts on what could be at work here?
SLegacy99 is offline   Reply With Quote
Old 03-13-2012, 02:18 AM   #2
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
'96 BrightonCoupeWRX-SR30
from the head or the block? can you post a video of it?
Kawikid20o2 is offline   Reply With Quote
Old 03-23-2012, 07:01 PM   #3
SLegacy99
Member#: 117504
Red
Old 03-23-2012, 10:24 PM   #4
redleg91
Member#: 307160
98 Legacy
Red
one of the timing belt pulleys? worth looking at. might be rubbing or hitting something. use a stethoscope to find where exactly its coming from
redleg91 is offline   Reply With Quote
Old 03-25-2012, 10:25 AM   #5
wondercow2
Member#: 130514
I had a bad new-style timing belt tensioner that made a similar noise. Run it with the covers off, if you haven't already.
wondercow2 is offline   Reply With Quote
Old 03-26-2012, 04:36 PM   #6
Kawikid20o2
Member#: 86291
'97 LegaSTi-2.5XTR
that sounds horrid, wow, so timing belt went on perfectly and was aligned right? definitely need to take a look inside that cover like wondercow said.
Old 03-27-2012, 04:59 PM   #7
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
Almost sounds like the valve lifter noise, but yowza, that's loud.
Wiscon_Mark is offline   Reply With Quote
Need some OT Mountain Biker Help - Need to get a new Bike Computer + Light sedagive Off-Topic 9 10-07-2009 10:44 PM
Locals: I need advice on HG replacement. badfish1134 North West Impreza Club Forum -- NWIC 11 07-14-2009 06:15 PM
Need some ideas for replacement rims(pics inside) Twiztidunreal Interior & Exterior Modification 20 12-29-2008 05:13 AM
Need some Greddy Profec B help kastle Factory 2.0L Turbo Powertrain 2 12-05-2002 02:33 PM
Need some new brake pads...help. View Askew Bay Area Impreza Club Forum -- BAIC 18 09-17-2002 03:59 PM
Message Board Statistics All times are GMT -4. The time now is 09:12 PM.
