Old 03-13-2012, 08:53 AM   #1
mmiller2002
Member#: 159286
2002 WRX Wagon,Com-C
RCE wgn sprngs/Konis/H6
Default How to find connector type so I can replace? (#2 coil pack)
I believe that I have an intermittent connection. How can I find out the connector type and get any pin insertion/removal tools so that I can replace the connector to my #2 coil pack?
Thanks,
Mike
mmiller2002 is offline   Reply With Quote
Old 03-13-2012, 02:51 PM   #2
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
Thanks,
Mike
Usually, you don't. The only real chance you have is to see if the company that made the connector has their logo on the connector. That's a no no for North America OEM's. No supplier can put their logo on the part they are supplying. Ford is the worst for this. Sometimes, Japanese OEM's allow it. Take a look. On the other hand, if the coil supplier made the connector, it's either Denso or Diamond, I can't remember which. Might say it on the coil.
If you do find the supplier, calling them and getting the tools might be difficult. If it says Deutsche (spelling might not be right), then you have a high chance of getting one. But I don't know if they suppy OEM. Could be a company called Molex, they make a LOT of connectors.
I work for an OEM supplier, and this is something even we struggle with. Take a picture, PM it to me, and I might be able to lead you in the right direction.
What makes you think you have an intermittent issue?
Bacon117 is offline   Reply With Quote
How to find gear ratio for my transmission so I can get correct rear diff!!! STIWAGON06 Transmission (AT/MT) & Driveline 3 01-09-2012 08:56 PM
A/C Compressor Oil - Unable to find correct type "Zexel Type R" ?? caterpill Service & Maintenance 3 09-23-2007 03:33 AM
how to split the tranny case? where Can I find the guide? IllNastyImpreza Service & Maintenance 0 05-07-2007 06:36 PM
I figured out how to bypass the immobilizer so 06 STI owners can user the 04 STI key Jag32 Car Audio, Video & Security 16 07-09-2006 10:05 AM
('93-'01) how to make car lighter so i can run faster gerardchau Impreza Forum 37 10-05-2001 04:47 PM
Message Board Statistics All times are GMT -4. The time now is 12:08 AM.
