Old 03-13-2012, 03:05 PM   #1
07RezaWagon
Member#: 291657
2007 2.5i Wagon
CGM
Default High pitched buzzing noise with fan on
This morning when I started my car up there was a somewhat loud buzzing noise coming from behind the glove box area. I turned off the fan and it went away so I'm thinking it has something to do with the fan that pushes air into the cabin. Kind of sounded like a leaf or maybe water.
How can I get to it?
I'm going to go take off the glove box since I know the cabin air filter is behind it and take a look around.
Thanks in advance
07RezaWagon is offline   Reply With Quote
Old 03-13-2012, 03:46 PM   #2
WRXSD
Member#: 136539
2005 WRX Wagon
CGM Stg. 2
Pull the glove box out as if you were going to replace your cabin air filter. The filter sits right over your cabin fan, so you will likely find the culprit there. You may want to consider replacing the filter while you are in there.
WRXSD is offline   Reply With Quote
Old 03-13-2012, 03:46 PM   #3
gar1013
Member#: 310707
2012 WRX Hatch
WR Blue Pearl
Thanks in advance
I once had that on a car...kept running fan at full blast and eventually a small sticker came flying out the vent.
gar1013 is offline   Reply With Quote
Old 03-13-2012, 04:28 PM   #4
07RezaWagon
Member#: 291657
2007 2.5i Wagon
CGM
Well I pulled out the filter and only found a tiny leaf and a couple pine needles along with a dusty filter which I vacuumed. But there were a few drops of water coming from the black tubing leading from outside (I think) into where the fan is. Could this be from running the A/C for the first time in a while? Or, since its been raining, could water make it in there?
The filter was damp in some areas so water must be getting in somehow
low sometimes high pitch buzzing noise? Strider327 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 07-29-2011 07:33 PM
High pitched whining noise on start up Seanco Newbies & FAQs 8 08-08-2009 11:10 AM
High pitched squealing noise Blizwinter Service & Maintenance 2 12-28-2003 09:26 PM
rattling + high pitched grating noise from right rear 98GTlegacy Transmission (AT/MT) & Driveline 0 12-02-2003 04:57 PM
High pitched buzzing Evaider Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-04-2002 02:56 AM
