#1 |
Member#: 311937
Vehicle:2005 WRX Wagon WRB |
Does this sound like a power steering pump issue or just a belt? It whines on start up and when I turn the wheel at idle (only after just starting up the engine).
#2 |
Member#: 118500
Vehicle:02 Silver Wagon "Stage 2" |
Belt. Usually a belt is kind of chirpy, which yours sounds like. Power steering pump is a whine, but it's a smoother whine, if that makes sense.
Probably just needs to be tightened. |
#3 |
Member#: 222724
E. Canada
Vehicle:2005 Impreza RS Regal Blue |
Mine did the exact same thing. I had replaced the belt and it had stretched alittle making it not as tight as it should be. The belt simply needed to be tightened and all was well.
Did you change your belt recently? |
#4 | |
Member#: 311937
Thanks for your helpful insight! |
| Thread Tools | |
| Display Modes | |
| WTB : Power Steering Pump or Pulley | Bugeye_Josh | Private 'Wanted' Classifieds | 2 | 11-20-2011 05:00 PM |
| Looking for a junk power steering pump or two | Mach V Dan | Mid Atlantic Impreza Club -- MAIC | 47 | 03-23-2011 01:24 PM |
| WTB: Subaru wrx power steering pump OR JDM RESERVOIR | mysubarusti4life | Private 'Wanted' Classifieds | 0 | 09-15-2009 03:07 AM |
| Belt is snapping - power steering pump? | jacob80 | Factory 2.0L Turbo Powertrain | 1 | 03-19-2008 07:03 PM |
| Leaking power steering pump or reservoir. | tonytiger | Service & Maintenance | 4 | 07-11-2002 03:08 AM |
