Old 03-13-2012, 10:01 PM   #1
02Shagginwaggon
Member#: 310253
Default Camshaft sprocket movement (Timing belt removal question)
When I removed the timing belt I accidentally moved the lower driver's side camshaft sprocket a few teeth one way and then quickly moved it back to where it was. Could this have caused any bent valves? Also, as long as I turn the sprockets in the correct directions, no harm can be done, no matter how many times I turn them, right?
02Shagginwaggon is offline   Reply With Quote
Old 03-14-2012, 08:51 PM   #2
leecea
Member#: 37359
2003 WRX
I turned mine all the way around at least 3 times doing my belt and no issues.
leecea is offline   Reply With Quote
Old 03-15-2012, 01:52 AM   #3
02Shagginwaggon
Member#: 310253
ok thankyou!
Old 03-15-2012, 09:48 PM   #4
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
The issue on dohc cars is hitting intake and exhaust valves together, so mind your Ps and Qs while spinning your cams. If your crank is lined up properly, you'll never hit the pistons.
CosmoTheCat is offline   Reply With Quote
Old 03-19-2012, 12:25 AM   #5
Xtream
Member#: 299267
2013 BRZ
This.
I'm positive you caused no damage.
Xtream is offline   Reply With Quote
broken timing belt cover + damaged exhaust camshaft sprocket Serkan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 05-03-2010 04:29 PM
Camshaft sprocket removal tool WRXfinn North West Impreza Club Forum -- NWIC 4 09-24-2009 10:36 PM
camshaft sprocket removal tool????? ayreshead7 Mid Atlantic Impreza Club -- MAIC 6 02-05-2008 11:34 PM
WRX DOHC 02-05 Camshaft Sprockets latinskllz Private 'Wanted' Classifieds 0 10-20-2004 11:03 AM
camshaft sprocket wrench? elvis Service & Maintenance 4 10-16-2002 10:16 PM
