Old 03-14-2012, 07:16 AM   #1
workinprogress
Member#: 310341
08 WRX Sedan
Default HELP! multiple brake lights, no dtcs
On my way to work this morning, as. I was slowing for a red light, the ABS light, trac control light, and hill stopper light all came on at the same time. Plugged in my Solus to check codes and I have no current, saved or pending DTCs. Brake fluid level is between min and max. No visible issues with the module that I can see as far as damage or leaks. Car is an '08 WRX sedan, stock, 39k miles. Any ideas?
-Dan
workinprogress is offline   Reply With Quote
Old 03-14-2012, 08:49 PM   #2
workinprogress
Member#: 310341
08 WRX Sedan
Guess I'm the only one it's ever happened to.
Old 03-15-2012, 12:48 AM   #3
aod12
Member#: 282701
2008 FXT
I've got an auto 2.5i and have had the abs and vdc lights pop up when I needed to change the pads. Not sure if it was related to that but once pads were changed the lights didn't pop on again.
aod12 is offline   Reply With Quote
Old 03-15-2012, 08:46 AM   #4
Bacon117
Member#: 118500
02 Silver Wagon
"Stage 2"
-Dan
It's still under warranty, yes? My idea is to take it to the dealer.
Bacon117 is offline   Reply With Quote
Old 03-15-2012, 09:49 PM   #5
CosmoTheCat
Member#: 3409
Did you check for VDC codes, or just ecm codes?
CosmoTheCat is offline   Reply With Quote
Old 03-16-2012, 07:03 AM   #6
workinprogress
Member#: 310341
08 WRX Sedan
I checked ABS codes and engine codes. Read live data from VDC and nothing. Checked pad thickness yesterday and I'm at < 3mm onthe front. If it's just from the pads being low I'm gonna feel really stupid. Ordered some Hawk HPS pads, light hasn't come on since yesterday morning. Will post results after replacing the pads.
Old 03-16-2012, 11:07 AM   #7
SHOfast
Member#: 99083
02 impreza
Are you able to communicate with those modules or are just not reading any codes?
SHOfast is offline   Reply With Quote
Old 03-18-2012, 09:13 AM   #8
workinprogress
Member#: 310341
08 WRX Sedan
I am able to communicate with everything. Using a Solus Pro updated to 2010 models. I can see the angles on the lon/lat sensors, warm ups, all saved dtcs, history dtcs, current dtcs, everything. I love it. Best 2k I ever spent.
Help! I need help my brake lights stop working Sco09 Tri-State Area Forum 7 10-09-2011 06:04 AM
Need help with brake light, abs light starcraft227 Brakes, Steering & Suspension 1 08-26-2011 01:25 AM
Help! I need help my brake lights stop working Sco09 Electrical & Lighting 1 05-14-2011 12:59 AM
ABS, Brake light, no speedo???? Phil4631 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 11-07-2010 01:10 PM
('93-'01) Help with brake lights and AC Impreza2.5RSTi Impreza Forum 12 11-13-2002 04:50 PM
