Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 03-14-2012, 09:56 AM   #1
renegado
Member#: 229488
Default IHI turbo relocation EJ20G
Hi to every one i just wonder to know if it is worth it to do the turbo relocation with an IHI VF22 the same convertion that it has to be done for example with the Gt35 rotating the turbo 45 degrees because of fitment issues, in my case the VF22 is fitted on my ej20g engine so it has to be fitted with a 90 degree hose, on my understanding with the rotation of the turbo i will just to use a straight pipe to fit the MAF and for so i will get better spool, im right?.
renegado is offline   Reply With Quote
Old 03-15-2012, 01:38 PM   #2
pmugabi
Member#: 280926
The VF22 is not a fast spooling turbo so you will have to bear with the late spool. Do you need a VF22 for your power goals?
I'm not sure how much restriction the 90 degree bend is but I doubt it's significant, also rotating a turbo its lots of work and probably not worth the gains.
For better spool, consider a smaller turbo. Porting the turbo and exhaust manifold will also yield noticeable spool improvements.
pmugabi is offline   Reply With Quote
Old 03-15-2012, 03:58 PM   #3
sizzflair
Member#: 94268
1995 JDM STi RA ver2
2010 Exige S240
90 degree bend shouldn't be a significant restriction... just weld on the 90 degree elbow on it and call it a day unless it bothers you that much.
I have a TD05H-20G with a 90degree elbow welded on.
sizzflair is offline   Reply With Quote
Old 03-16-2012, 11:57 PM   #4
Subbiespeed
Member#: 276493
2005 STI
i have a vf28 with a welding 90
Subbiespeed is offline   Reply With Quote
Old 03-17-2012, 06:55 PM   #5
bluemk3
Member#: 263694
World Rally Blue
a vf22 is a bolt in stock location turbo. why mess with that....? if you want to do a rotated turbo get a turbo that would make sence to do it with. a gt28 or a gt30 have similar power capabilities as a vf22. but arent as plug and play as the vf22..
bluemk3 is offline   Reply With Quote
Old 03-17-2012, 07:29 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
the vf22 is not a direct plug and play.
eg33GC is offline   Reply With Quote
Old 03-18-2012, 08:18 PM   #7
bluemk3
Member#: 263694
World Rally Blue
News to me.. Can you elaborate. I'm curious what's the difference
Old 03-18-2012, 10:33 PM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
the inlet systems for v1/2 is much different than 3+.
IE no silly under manifold inlet routing
Old 03-19-2012, 05:31 PM   #9
bluemk3
Member#: 263694
World Rally Blue
My bad.didn't look at the g after the ej20....
Turbo relocation - anyone done it? Bad Noodle Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 07-31-2009 08:17 AM
Stock turbo heat shield fits IHI turbos? skycruise Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-12-2004 12:29 PM
Turbo Relocating? Tur1smoWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-29-2003 06:56 AM
Air flow meter problems with turbo relocation alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 08-19-2002 11:00 AM
what ihi turbo came on the legacy turbo? bill harvey Legacy Forum 1 10-11-2000 05:46 PM
