Old 04-27-2001, 11:10 AM   #1
deke
Member#: 5313
2002 WRX Wagon
World Rally Blue
Post Check Engine Light
Well, I had a scary surprise in my new WRX Wagon. After my first fill up I was driving along, feeling happy. I look down at my dash and see the check engine light. Fantastic! Here I am in the middle of nowhere. Turn the car off, turn the car on - the thing is still glowing. Call Subaru roadside - recording tells me the wait will be long (thanks) I hang up. I look through the manual and see a little blurb that if you don't seal the gas cap completely, you could get a light. I open the gas door and see a little sticker warning me that not sealing the cap can cause a check engine light. Later I call my dealer - he tells me it happens all the time. It seems the WRX has the most sensitive emissions system around. He even warned me not leave the ignition on during a fill up (to listen to the radio) because that could trip it too. He said the light can go out on its own, but sometimes needs to be reset (anyone know how to do that). Mine finally went off after another fill up. How much you want to bet that if I ever get a real light I will think it is the gas cap?
[This message has been edited by deke (edited April 27, 2001).]
deke is offline   Reply With Quote
Old 04-27-2001, 11:27 AM   #2
popnGEAR
Member#: 4616
1999 2.5RS
RBP
Post
well i think resetting the ecu in the rex would be the same as an RS, but odn't quote me on that. Disconnect the battery for 30 mins, reconnect it, start the engine, let it idle for around 30 minutes, turn off engine, start up again and your done.
popnGEAR is offline   Reply With Quote
Old 04-28-2001, 12:05 AM   #3
KC
Member#: 442
13 Crosstrek XV
00 S2000
Post
IBTL...
Check the WRX Non-Tech forum.
This really is nothing new. Take the keys out of the ignition when you fill up, you cannot listen to the radio.
Keys even in the accessory position will engage (turn on) the ECU. The ECU will see a pressure loss in the fuel system, but not trip the CE light until many miles later.
Just take out your keys.
--kC
[This message has been edited by KC (edited April 27, 2001).]
KC is offline   Reply With Quote
Check engine light, VDC light is on, and cruise control light is flashing grimace09 Normally Aspirated Powertrain 7 08-09-2012 03:42 PM
Check engine light, VDC light is on, and cruise control and sport light is flashing Legacymun2k6 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 01-30-2010 12:47 PM
check engine light, wierd engine trouble? gipoliceman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-14-2003 09:04 PM
Engine coolant temp sensor check engine light? rhdude Mid Atlantic Impreza Club -- MAIC 2 11-09-2002 02:42 AM
Engine vibrating, check engine light on codemunky Service & Maintenance 2 09-15-2002 07:50 AM
