Old 08-20-2002, 11:26 AM   #1
SubaruLover
Member#: 6180
1999 Impreza
Deuce-Deuce
Default O2 sensor problem . . .
i have a 99 Subaru impreza L w/ 46,000 miles will this be under warrenty? or is it possible to take it back to the dealer the car was purchased and see if they would make an exception and do it under warenty any way?
thanks,
Brad
SubaruLover is offline   Reply With Quote
Old 08-20-2002, 01:48 PM   #2
Siper2
Member#: 1134
2007 BMW 328xi wagon
Smile
Don't worry, you're covered.
There's an O2 sensor Parts Recall for the 2.5L engine type (engine code name EJ25). The Parts Recall number is WXW80.
It's free. Being a Parts Recall, you don't have to be under warrantee, it's a national recall.
Be it that you need to replace the sensor once, or a thousand times, it's free. It's a faulty sensor, that's why. I've replaced mine in my 2000 Impreza 2.5RS five times.
If the dealership gives you grief, tell them to look up the Parts Recall number. If they give you more grief, call Subaru of America at 1(800)SUBARU-3 and tell them about it. They'll straighten the dealership out for you.
-S2-
Siper2 is offline   Reply With Quote
Old 08-20-2002, 06:07 PM   #3
SubaruLover
Member#: 6180
1999 Impreza
Deuce-Deuce
does the recall include my car i have a 2.2L
Old 08-20-2002, 11:05 PM   #4
Siper2
Member#: 1134
Damn.
I knew that, too. Why'd I go off on my 2.5L shpeal?
D'oh.
I've no idea about the 2.2L engines, but I assume it'd be the same deal. Call SOA, they can tell you. Maybe mention that you know there's a Parts Recall for the EJ25, you were just wondering about yours, too.
-S2-
Old 08-22-2002, 12:07 PM   #5
SilverBoosted
Member#: 7764
11 Edge Sport
Kona Blue Metallic
Siper youve been lucky... A recalled item is replaced with an updated unit that should no longer be defective so it will not qualify to be replaced more than 1 time..... If youve had 5 o2 sensors repl there is something more going on than we know. I doubt it is because of the recall . Have they all been repl in a short span of time?? If so than maybe a parts warr was performed (all installed parts have a 1 yr warr)..... A recall is performed 1 time per car thats it .....
SilverBoosted is offline   Reply With Quote
Old 08-22-2002, 09:18 PM   #6
Siper2
Member#: 1134
No consistency to it, really.... though I guess it's averaged one every 10,000 miles or so. Excepting the last one, which I had to have done in half that time or less, I think.
I know a recall's only should be done once, but the parts are obviously still defective, nobody's been able to get the damned thing to work. My feeling is that this is why SOA recalled a lot of EJ25 cars to have their ECMs reprogrammed, because they were blowing O2 sensors. So maybe it's partial fault to the sensors being poor, partial fault to the ECU maybe making the engine run a little bit wrong, causing the blowout.
I'm not the only one, there's quite a few members that've replaced more than I have. Theirs were free too, as I recall. They bloody well should be.... it's not my damned fault the things keep blowing.
-S2-
Solutions to Wide Band o2 Sensor Problem... Needed jfalcon001 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-29-2002 05:01 PM
O2 sensor problem w/S-AFC and A/F ratio gauge Scoobyslack1 Normally Aspirated with bolt-on Forced Induction Powertrain 6 09-05-2001 03:38 PM
THERE IS A RECALL FOR MY00 RS FOR O2 SENSOR PROBLEM CALL YOUR DEALER CHACHI Normally Aspirated Powertrain 12 04-07-2001 03:07 PM
o2 sensor problems, lean A/F mixture. Help me! Quart2000 Normally Aspirated Powertrain 0 02-07-2001 07:29 PM
O2 sensor problems ac_gohan Bay Area Impreza Club Forum -- BAIC 0 01-23-2001 01:47 AM
