Old 03-14-2012, 09:06 PM   #1
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
Default joining the "RT6" club now
2011 WRX
stage 1 sf 91 ots
cobb intake plus box
spt cat back
dumped factory fill at 2000 miles.
followed aggressive break in process
4000 miles now.
well just changed oil with m1 extended performance 5w30 with oem filter. wrx consumed 1.4 qts of m1 in 2200 miles. following the majority with the shell rotella t6 5w40 to hopefully end my consumption issue. unloaded my m1 stock and replaced it with a bunch of t6. always use oem filters and going to drop the m1 in it currently within the next couple of weekends. bummer really about these engines hating this oil, been using it for years and was loyal to the brand but guess its over. ill follow up when i do the change and see how the oil performs.
(please no rage debates over oil selection, factory fill change interval, break in process, I.Q., etc. just sharing my experience with my car.)
HeroCrank is offline   Reply With Quote
Old 03-14-2012, 09:32 PM   #2
bluesubie
Member#: 767
04 FXT
Consumption is normal, especially on a new engine. You can also have consumption when switching brands because of the different oil chemistries. If you've been happy running Mobil1, the brand is fine as long as you run the proper viscosity for your application. M1 0W-40 and TDT 5W-40 are very good oils. People here tend to compare M1 5W-30 to RT6 5W-40 which makes no sense. Of course, RT6 is good oil as well.
-Dennis
Old 03-14-2012, 09:36 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I just wish the damned T6 came in a 5qt jug
Old 03-14-2012, 10:10 PM   #4
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
that is very annoying and i ended up just getting more gallon jugs instead of buying that seperate quart for 6.54
Old 03-14-2012, 10:19 PM   #5
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
-Dennis
yeah ive planned on having more consumption before the t6 is established in the motor. i did see the m1 5w40 and read the info on the jug, but decided against it. im very curious to see how the t6 works out. ive seen all the comparison threads of the two (m1 5w30 vs the t6) and was leary about making a post in fear it would explode, which i really hope that it does not. ill be more patient with my car since its still low miles and the consumption is still normal, but just bummed out that it is consuming so much. on a side note ive read alot of you guys threads on here and appreciate your knowledge and time you take to post on these forums.
Old 03-15-2012, 03:42 AM   #6
subi400
Member#: 216984
1996 Impreza outback
Green
^^ Yeah, I agree!!!
subi400 is online now   Reply With Quote
Old 03-15-2012, 06:29 PM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
ive been mixing a quart of the 10w40 mobil 1 racing 4T with the T6 gallon
Old 03-15-2012, 10:33 PM   #8
Ernest
Member#: 45076
2004 Stg2 Wagon 4eat
I mix with whatever synthetic 5 w30 i have around. No issues.
Ernest is offline   Reply With Quote
Old 03-16-2012, 03:40 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
....i dont have any 5w30 around...its useless
Old 03-18-2012, 08:17 PM   #10
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
that oil sounds like it has a robust additive package. very curious about it, will do some reading up on that oil.
Old 03-19-2012, 11:16 AM   #11
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
I've been using G.C. 0w30 for the extra. Kind of a P.I.A. as I get the T-6 at Wally-World and the G.C. at AutoZone. RP
drivin blind is offline   Reply With Quote
Old 03-20-2012, 03:01 AM   #12
Uncle Scotty
Member#: 16200
OK buy Nates beans
i been doing the 'reading up' on lubricants for years and years, now
Old 03-20-2012, 04:43 PM   #13
subi400
Member#: 216984
Green
Will be doing this ^^^ on my next oil change
Old 03-23-2012, 05:02 PM   #14
Neutron
Member#: 215419
08 STi
Don't post much but been trolling for years. I just flipped 45k on the car which is an 08 STi. I did 1200 on the factory oil. Then 1200 on Penzoil conventional yellow 5w30 with no filter change. Then I changed it about every 3-4 k with Mobil 0w40. Top rated "cheap" oil that is easily obtainable per the guys at bobistheoilguy.com. Last fill I just did RT6. So I have done about 12-13 oil changes and burned about 3 quarts total (probably less). About 15 auto crosses on top of it. 0w40 is "God's"oil. 0w40 is the only Type IV that you can get from Mobil. Mobil ratings are on the high side so I would never consider 0w20/30 from them. I don't have UOA's but the engine is as smooth as the day I took her home. Probably better.
If you have oil or any type of engine liquid questions, try www.bobistheoilguy.com
Those guys are nuts on fluids.
Neutron is offline   Reply With Quote
Old 03-24-2012, 04:52 AM   #15
subi400
Member#: 216984
Green
What about taking a quart of the Mobil 1 0w50 racing oil and adding that to 3 1/2 quarts of the T-6 5w40?
Old 03-24-2012, 05:04 PM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
oh jesus h ****ing christ
Old 03-24-2012, 10:36 PM   #17
SubieMonte
Member#: 264803
2005 WRX Wagon
Orielly's has the gallon jug of RT6 on sale for 19.99, right now. Got me two...
SubieMonte is offline   Reply With Quote
Old 03-26-2012, 02:51 PM   #18
subi400
Member#: 216984
Green
So your so called adding a 10w40 mobil motor cycle oil is any better..hmm??? If I have a built engine running a 5w40 or 5w50 or whatever, then it wouldn't hurt would it
Old 03-26-2012, 03:27 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
man....this is one of those "if ya gotta ask...." kind of things...
make up your own mind
and just dump the whole 5 quarts in it....no REALLY
Old 03-26-2012, 03:27 PM   #20
Uncle Scotty
Member#: 16200
OK buy Nates beans
hey..that's a pretty good deal on that
Old 04-10-2012, 07:55 PM   #21
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
update: currently have 600 miles on the T6. zero oil usage as of now. my driving habits have not changed and have followed the same driving routes as usual. with 600 miles on this oil I would be on pace to consume around 1/2 of a quart of 5w30. the T6 is working out great so far and will be updating as my miles on the oil increase. on a side note, I will be going stage 2 very soon. cobb catted dp and spt boost gauge has arrived. stage 1 has become very dull feeling.
Old 04-10-2012, 10:02 PM   #22
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
good to hear, i am jumping on the bandwagon with t6 also, will be dumping the oem oil when i have some free time on the weekend, sitting at 1400 miles on it now..
BigRob74 is offline   Reply With Quote
Old 05-23-2012, 06:21 PM   #23
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
update---- 1,700 miles on the T6. stage 2 now, and zero usage so far and the oil looks great still.
Old 05-24-2012, 04:34 PM   #24
italy wrx
Member#: 36450
2003 WRX
O'reilly's has T6 on sale for $19.99...
italy wrx is offline   Reply With Quote
Old 09-02-2012, 07:13 PM   #25
HeroCrank
Member#: 301089
2013 Toyota Tundra
Rock Warrior
update: 8,000 miles on car, two T6 changes, zero consumption or oil loss between changes. awesome oil and an awesome decision.
How do i join the Midwest club ? nor1212 Mid West Subaru Owners Club Forum -- MWSOC 12 10-26-2003 05:42 PM
Joined the Utec Club! mbiker97 Engine Management & Tuning 15 02-01-2003 03:34 PM
('93-'01) Is this a good deal? I REALLy wanna join the Rex CLUB!! iemonslice Impreza Forum 11 08-02-2001 06:38 PM
Can I join the RS-T Club? Delicious Tuning Bay Area Impreza Club Forum -- BAIC 22 07-24-2001 09:55 PM
I almost joined the crash club last night. redobs New England Impreza Club Forum -- NESIC 3 10-19-2000 11:15 AM
