Old 03-15-2012, 03:05 PM   #1
whitemk3
Member#: 107455
Default 06 sti starting problem
Im new to the subby world and looking at some advice on what the problem could be. Car has started perfect every day every time went today and washed the car off nothing out of the ordinary well when i got back in the car to start it all the lights come on everything normal but when i went to start it there was nothing no sound out all. So i waited a second maybe thinking my foot wasnt all the way on the clutch and tried again and it started fine. Went to eat afterwards car started fine. Drive it to the store and get back in it and it wont start again but this time it never would start. So i had to push start it to get it home get it home turn it off and try to start it again and it starts fine. any ideas what it could be
whitemk3 is offline   Reply With Quote
Old 03-15-2012, 03:37 PM   #2
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
possibly bad starter contacts but also check your battery and terminal connections
bugeye829 is offline   Reply With Quote
Old 03-15-2012, 10:11 PM   #3
Fred
Member#: 3560
06 STi, 02 STi
06 FXT, 94 rally car
It sounds like the clutch pedal switch is sticking - this happened to mine. Next time it won't start, try kicking the clutch pedal a few times while holding the key turned. If it suddenly starts, replace the switch that interrupts the ignition (there are two of them, and it's the one on top). Or just cut the wires off it and splice them together, like I did mine. Then you'll never have that problem again.
Fred is offline   Reply With Quote
Old 03-23-2012, 06:13 PM   #4
whitemk3
Member#: 107455
well i replace the clutch pedal switch today and it did the excact same thing again if i kick the clutch a few times it usually starts. so im kind of at a loss
Old 03-23-2012, 06:28 PM   #5
Fred
Member#: 3560
06 STi, 02 STi
Which one did you replace?
Old 03-23-2012, 07:32 PM   #6
whitemk3
Member#: 107455
the top one that you talked about
Old 03-24-2012, 09:46 AM   #7
whitemk3
Member#: 107455
went and got the starter check its good along with the battery
Old 03-26-2012, 10:44 PM   #8
whitemk3
Member#: 107455
any other ideas
Old 03-27-2012, 12:05 AM   #9
Fred
Member#: 3560
06 STi, 02 STi
Well, if it doesn't do ANYTHING when you turn the key, and then it cranks when you kick the clutch pedal, it's obviously something clutch-pedal related. So that's where I'd look.
04 STi starting problems and engine hiccups metallifreak44 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 05-06-2014 01:04 AM
06 Sti start and idling at 4.5k.. HELP! ZAG_WRX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-13-2012 02:16 PM
06 wrx cluster swap to the 06 sti cluster problems... knighter Electrical & Lighting 1 10-07-2009 09:14 PM
Project 06 STI STARTS!!!! Jhovany Newbies & FAQs 0 03-21-2008 02:59 AM
06 sti exhaust problems 06blacksti Newbies & FAQs 9 02-06-2006 12:43 PM
