Old 03-15-2012, 03:40 PM   #1
eg33GC
Member#: 206851
56 Belair
Pro Street
Default evoscan cable
Some of us like to butcher our wiring harnesses, so we can't use the evoscan pnp unit
My FTDI 3v3 won't connect anymore, so maybe it went, or maybe it was the wrong voltage level all together?
my question is:
rs232-3v3
OR
rs232-5v
thanks
eg33GC is offline   Reply With Quote
Old 03-16-2012, 06:17 AM   #2
pmugabi
Member#: 280926
This might apply to you:
I had an issue with intermittent connections with the Evoscan cable connection to the stock wiring harness on a car.
I relocated the OBD1 connector and spliced it in right at the ECU. I had no issues after that.
pmugabi is offline   Reply With Quote
Old 03-16-2012, 12:16 PM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
You need the 5 volt cable.
Old 03-16-2012, 03:22 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
Thanks gents.
I had it directly wired, but the damn thing isn't even tripping my usb detection. Must be done.
Old 03-31-2012, 08:44 PM   #5
eg33GC
Member#: 206851
56 Belair
Pro Street
Having issues connecting with this cable..
wiring directly to the ecu at the plugs, and grounded to the chassis.
It connects, calls the ecu id 00000, and autoretrys. Any idea?
Old 03-31-2012, 08:59 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Have your rx and tx backwards?
Old 03-31-2012, 09:02 PM   #7
eg33GC
Member#: 206851
56 Belair
Pro Street
nope, I checked for that and I get a failed initialization error
this is so damn infuriating as I used to have 0 issue on another obd1 jecs ecu engine using the wrong damn cable (3v3)
Old 03-31-2012, 09:11 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
You trying to read a burned chip or the stock rom from a chip on the board? You might have a bad chip.
Old 03-31-2012, 09:17 PM   #9
eg33GC
Member#: 206851
56 Belair
Pro Street
just trying to datalog using my chips. if they were bad the car wouldn't run
Old 03-31-2012, 09:29 PM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
Maybe the handshake or ecu id data is corrupted?
Probably just a cable problem though.
What's the ftdi part number you got?
Old 03-31-2012, 09:36 PM   #11
eg33GC
Member#: 206851
56 Belair
Pro Street
232r-5v-we
Evoscan recognizes it in the com ports.
tx, orange #4 on cable, rx, yellow #5
ground to dash beam
Old 03-31-2012, 11:40 PM   #12
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
short J1 and see if you can communicate with the stock ROM.
rob is offline   Reply With Quote
evoscan 1.3u cable pin layout Nimm Open Source Reflashes 7 03-08-2011 07:41 PM
Tactrix or EVOScan cable needed in Central NJ. stangzroastrice Tri-State Area Forum 2 10-16-2009 06:27 PM
Would this $57 EvoScan cable work for logging w/ RomRaider? Zoinks Open Source Reflashes 5 09-10-2009 02:37 PM
EvoScan/StiScan with Cobb APv1 cable SSLegacyGT Open Source Reflashes 16 08-21-2009 06:53 PM
EvoScan Datalogging cable and Xpt map?? Dstretch33 Open Source Reflashes 8 09-04-2008 11:07 AM
