Old 03-15-2012, 10:20 PM   #1
jollyblue84
Member#: 292300
01 GC8
blue
Default Fuel question for a ej20g
What is the highest octane I can run in the stock ej20g?
jollyblue84 is offline   Reply With Quote
Old 03-15-2012, 10:45 PM   #2
eg33GC
Member#: 206851
56 Belair
Pro Street
anything over 91?
eg33GC is offline   Reply With Quote
Old 03-15-2012, 10:48 PM   #3
jollyblue84
Member#: 292300
01 GC8
blue
So I can run 104 octane?
Old 03-15-2012, 10:56 PM   #4
eg33GC
Member#: 206851
56 Belair
Pro Street
yeah but it won't do you any good over 93. and don't use leaded fuels.
Old 03-15-2012, 11:32 PM   #5
jollyblue84
Member#: 292300
01 GC8
blue
I thought in the jdm motors it would run better with a higher octane. Don't they use higher octane then the. U.S.?
Old 03-16-2012, 12:16 AM   #6
BobbyGF8
Member#: 294040
1998 JDM WRX GF8
RED
it could be, but in US I guess you'll find 93 octane as the highest. For example, if you buy airplane Avgas, it has 100/130 octane but is leaded fuel.
Airplane engine use leaded gasoline so this way they can lubricate valves seats.
BobbyGF8 is offline   Reply With Quote
Old 03-16-2012, 03:27 AM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
The way they measure octane in Japan is not equivalent to the US. If you don't have cats it is ok to use leaded gas at the track. Higher octane than the car was tuned for lets the computer max out the timing even as ambient temperatures increase.
I regularly fill up our two track cars with 110 leaded even though they are tuned for 91 and meth
Old 03-16-2012, 03:31 AM   #8
eg33GC
Member#: 206851
56 Belair
Pro Street
The 02 sensors will fail quicker with lead, and the early ecus really like their 02 readings. So keep that in mind
Old 03-16-2012, 03:39 AM   #9
ciper
Member#: 15543
90BJ Legacy LS ABS
The will fail faster. But universal sensors are pretty cheap, maybe I shouldn't assume but if he is asking about higher octane I assume its not for street usage.
Old 03-16-2012, 07:23 AM   #10
pmugabi
Member#: 280926
About the early ECUs liking their O2 readings - if you totally disconnect the 02 sensor, the car will drive fine (although the AFRs will be a bit rich at idle - about 12.0 AFR IIRC)
Universal sensors are cheap and also seem to fail fairly quickly.
pmugabi is offline   Reply With Quote
Old 03-17-2012, 12:54 AM   #11
Subbiespeed
Member#: 276493
2005 STI
don't say that i just put mine in today
Subbiespeed is offline   Reply With Quote
Fueling Question for Turbo Swap Oxcart Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 08-31-2008 12:01 PM
EJ20G Fuel Questions stigc8 Pre-2002 Factory Turbo Powertrain 10 03-21-2008 10:42 AM
Fuel Question for turbo swap NoMoreNeon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 02-08-2007 09:11 PM
Fuel Question for turbo swap NoMoreNeon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-08-2007 04:12 PM
spark plug question for jdm EJ20G scobaru Subaru Conversions 3 03-09-2004 12:53 PM
