Old 03-16-2012, 03:45 AM   #1
engelman27
Member#: 273311
2002 Mazda miata
Default 09 wrx- changing tranny fluid... Uncle scotty??
So im changing the tranny fluid in 5mt 09 wrx. Gonna go w "the Uncle Scotty's Cocktail of 1qt Redline lightweight shockproof, 1qt Pennzoil or GM Synchromesh, 2qt Castrol HypoyC 80w-90"?!?! Is this ok?
Also Im gonna do the rear diff gear oil. Anyone know the weight and amount on this ??
engelman27 is offline   Reply With Quote
Old 03-16-2012, 04:48 AM   #2
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
use the heavyweight shockproof
buy another quart of the hypoyc for the rearend...it should take a bit over half
Old 03-16-2012, 01:06 PM   #3
engelman27
Member#: 273311
2002 Mazda miata
Uncle Scotty himself! Ok than, so its about 3.8 quarts in the tranny and 1/2 in the rear diff?
Old 04-05-2012, 01:05 AM   #4
fulltimeW.O.T.
Member#: 120414
2009 WRX 5Dr DGM
Stage 2+Meth
im interested in this cocktail for my 09 too. Definitely go with heavyweight shockproof. lightweight doesn't do much.
uncle scotty my question for you is, why us castrol over redline MTL and/or MT-90, 75w90NS. I remember back in the day when I had my 2005 2.5rs, the cocktail involved all redline products.
Here is what I have in mind for sure at this moment. First quarts are definitely going to be Heavyweight Shockproof, Penzoil Syncromesh. Now should the rest be Castrol Hypoy Gear oil? Even Grimmspeed seems to recommend this cocktail(they suggest lightweight shockproof instead of heavyweight for some reason). My heart is with redline products tho
Any input is appreciated. Anyone currently running this Grimmspeed Cocktail? But with heavyweight shockproof instead of lightweight?
fulltimeW.O.T. is offline   Reply With Quote
Old 07-09-2012, 09:22 PM   #5
CletusTheDwarf
Member#: 27620
2009 Subaru WRX
Is there really a noticeable gain by going with this cocktail instead of just straight lightweight shockproof? Seems like a lot of effort to buy all these different kinds and mix them.
CletusTheDwarf is offline   Reply With Quote
Old 07-09-2012, 10:04 PM   #6
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
No. It is probably the first known "consistently great" transmission fluids. There are others now that are easier listed in the Maintenance FAQ.
Old 07-11-2012, 01:54 PM   #7
jonno
Member#: 283263
Since using the heavyweight in the cocktail was recommended in place of the actually written lightweight, should heavyweight be used in place if just doing that by itself?
jonno is offline   Reply With Quote
Old 07-11-2012, 02:29 PM   #8
Uncle Scotty
Member#: 16200
OK Houston
we have an Uncle
d000000000000000000000000000000000000000
000000000000000000000000000000000000000000000
000000000000000000d
is this really so hard to understand??
READ post #1
READ post #2
T H I N K for as long as it takes to make sense......unless that is more than a second or so....and act
if thought takes more than 2 seconds......do this
get big bucket of gasoline and lighter...put lighter in pocket for later use
put bucket of gas on roof of car...climb up on roof...pour gasoline over your head.....take lighter out of pocket and light lighter at least ONCE
report results here if possible
Changed tranny fluid at 9K, it is noticibly darker than new fluid. Please help! 4EAT Obsessive Transmission (AT/MT) & Driveline 4 07-07-2010 12:04 AM
changing tranny fluid and differential fluid for first time Durmiente Transmission (AT/MT) & Driveline 16 05-23-2007 02:06 PM
('93-'01) When am I supposed to change tranny fluid? Die Civic Impreza Forum 2 07-16-2001 04:08 PM
changing tranny fluid - instructions? goose Newbies & FAQs 7 05-24-2001 06:45 PM
changing Tranny Fluid goose Newbies & FAQs 3 05-16-2001 12:10 AM
Message Board Statistics All times are GMT -4. The time now is 07:06 PM.
