Old 03-16-2012, 04:02 AM   #1
CobbsSTI
Member#: 245242
2005 STI
E85 Power
Can an exhaust leak pre turbo cause a stutter like affect or something similar? I think its a leak at one of the flanges pre turbo, it seems that once the exhaust heats up and expands at one of these flanges the leak stops and so does the stutter, its only on start up when the exhaust is cold, and there is no boost/vacuum leaks. Suggestions/ideas?
CobbsSTI is offline   Reply With Quote
Old 03-16-2012, 01:55 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
Put it up on a lift and take a look. If there is a leak between the exhaust manifold and the turbo, it'll be easy to see - just look for carbon splatter. Is your boost spool-up noticeably slower?
flycaster is offline   Reply With Quote
Old 03-16-2012, 02:00 PM   #3
APM Tuned
Member#: 282460
2005 Evo-STI
R.R.-WRB
what he said, there will be carbon build up where the gaskets or flanges have failed and also like he stated, there will be a decrease in spool up efficiency, a bit more noise and slower response in power.
Also, being that the leak is in front of you, the faint exhaust gas smells will enter the cabin with windows closed and no ventilation from A/C or heat.
-Mark
APM Tuned is offline   Reply With Quote
Old 03-16-2012, 02:25 PM   #4
CobbsSTI
Member#: 245242
2005 STI
E85 Power
Thanks guys, boost seems to be ok when the exhaust heats up, like I said once it heats up the leak goes away cause of the metal expanding. I've only got into boost once the cat heats up pretty good and it seems fine, havent got on it when it was cold and leaking to tell if boost was lagging
Old 03-16-2012, 02:29 PM   #5
CobbsSTI
Member#: 245242
2005 STI
E85 Power
On first start of the day ill let it warm up a lil before I go, I looked under the car and noticed that there was some water coming out of the flange where the header meets the up pipe so I'm guessing the leak is there. The water is just condensation built up in the exhaust from sitting over night so I know that's ok.
Old 03-16-2012, 07:50 PM   #6
flycaster
Member#: 60142
2011 WRX
Grey
OK, so what makes you think it has a "cold" leak? Can you hear it and see some carbon evidence somewhere? Frankly, that water you see could easily be dripping down from somewhere else.
Also, what's this "stutter" thing you mentioned? A small pre-turbo exhaust leak will just cause slower spool-up; it shouldn't make the car run rough, IF that's what you're trying to say. Tell us more.
Old 03-16-2012, 10:54 PM   #7
CobbsSTI
Member#: 245242
2005 STI
E85 Power
Like I said the exhaust leaks when it isn't fully warmed up, its leaking at the header to up pipe flange and yes I do see carbon there, I can he it but when it warms up fully the sound and the slight stutter goes away, now the stutter only happens when I get on it and the exhaust isn't all the way warmed up, it doesn't leak when its warmed up all the way cause of the metal expanding and sealing the leak.
Old 03-16-2012, 11:02 PM   #8
CobbsSTI
Member#: 245242
2005 STI
E85 Power
I've watched the flange closely on start up for the first time of the day and the water is dripping from the flange cause of the condensation built up in the exhaust and its leaking through the leak in the flange where the gasket is, so my question is can this leak cause a slight stutter if not fixed, cause it only does it when the sound of the leak is there then goes away once warmed up and the sound of the leak goes away.
Old 03-17-2012, 01:45 AM   #9
flycaster
Member#: 60142
2011 WRX
Grey
The question is irrelevant. You have a leak, fix it.
Old 03-17-2012, 03:28 AM   #10
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
I have a 06 sti and this sounds like what I got going on I get a exhaust smell at wot and my spool up seems to be a bit slow where is the first places I should check for a leak the car still pulls hard and runs fine but the smell I figured was from catless.
Coreycarlile911 is offline   Reply With Quote
Old 03-17-2012, 03:34 AM   #11
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
-Mark
I prob should have been asking you this question from the post above I quoted the wrong person also the exhaust smell is random regardless of hot or cold so could this be something other than leak?
Old 03-17-2012, 10:19 AM   #12
flycaster
Member#: 60142
2011 WRX
Grey
Does this happen all the time, or perhaps right after oil changes? Do you see any evidence of small oil leak(s) anywhere (floor drips, oil on the cross member, etc.)? Is everything tight and well sealed from the exhaust manifold to the tail pipe?
Old 03-17-2012, 02:31 PM   #13
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
No oil leaks that I can see but I have to borrow ramps and tools from my friend so I havent gotten to check yet so was wondering of spots to check first
Old 12-11-2012, 08:58 PM   #14
vhsc22
Member#: 217417
2005 STI
I think I'm having this problem..
vhsc22 is offline   Reply With Quote
Old 04-13-2013, 03:02 PM   #15
nutinbuthehits
Member#: 214758
bump from the dead! im also having this problem. this exhaust leak IM HOPING causes the slight stutter/hesitation that you talking about, because i have it also
nutinbuthehits is offline   Reply With Quote
Old 05-09-2013, 12:36 PM   #16
Lurk
Member#: 222686
95 WRX Coupe
Yeah me too
Upon started up / warm = no noises, weird idling, smells...car is great!
Just when I drive and I give it gas OR go into boost the car hesitates, sputters, hits fuel cut (im on the gas pedal and nothing happens) then the car lunges forwards, then pauses and goes again... kinda builds boost then hesitates /pauses / sputters
So If i drive like a grandma and dont go up hills im fine...
I have a few silly parts on the car...came with the car
Aftermarket = td05 turbo with after market wastegate, flex up-pipe, HKS blitz blow off valve,
OEM parts = headers, turbo back exhaust, gaskets, intercooler, I just rebuilt the whole engine so thats tits
Im thinking its the up-pipe, wastegate, BOV or the turbo inlet...its kinda busted or its that cheap turbo... If I find anything Ill let you know
Lurk is offline   Reply With Quote
Old 05-10-2013, 02:31 AM   #17
locdogg
Member#: 325793
2012 WRX
Pearl White
Mine has oil splattered over a hose from the intercooler
locdogg is offline   Reply With Quote
Old 05-10-2013, 09:54 AM   #18
roadtrip1098
Member#: 185688
2006 STi
WR Blue
There are 2 very common gaskets that go bad. A two bolt one fromt he header to up-pipe and a 3 bolt one from the up-pipe to the turbo.
Jerky behavior, weird idle usually points to a vacuum leak. Check your PCV hoses, also the line from the intake manifold to the recirc valve. Both pretty common.
roadtrip1098 is offline   Reply With Quote
Old 05-10-2013, 10:28 AM   #19
nutinbuthehits
Member#: 214758
the uppipe to turbo gasket was the culprit for me. i changed it and havent had any problems since
Old 06-29-2013, 01:34 PM   #20
johnblahuta88
Member#: 221614
mine is having a low hissing at a idle. its annoying. I need to take off the heat shields and check it out
https://www.youtube.com/watch?v=AIzPzDzDcKM
johnblahuta88 is offline   Reply With Quote
Exhaust leak? or turbo spooling? eep4_dc5 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-20-2010 11:16 AM
Exhaust leak after turbo swap? theprodgalson Newbies & FAQs 8 03-03-2010 01:32 AM
Pre Turbo exhaust leak...... abosworth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-16-2007 10:15 AM
Exhaust leak or turbo noise? 06AspenWhite Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 10-29-2006 11:53 PM
occasional exhaust leak after turbo Jeff02WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-21-2003 07:40 PM
