Old 03-16-2012, 11:26 AM   #1
Dartholomew
Member#: 208771
2009 WRX
Default Climate fan on/off?
Not sure if this is a problem or WAI...also not sure if this is really the right forum so mods please move as appropriate.
Ever since I got my '09, I've noticed there's very little difference between having the climate control set off, or on the lowest setting. Especially at freeway speeds, it feels pretty much the same and I find that I need to point the vents away from me to avoid having a stream of air come at me even with the climate control off.
Is this normal (one of the things everyone puts up with from the WRX's econobox roots) or just me?
Dartholomew is offline   Reply With Quote
Old 03-16-2012, 02:16 PM   #2
rkramer
Member#: 118209
2015 WRX Limitec
That is basically a 'feature' of every car on the market. Due to aerodynamics some vehicles have more air going through them, but every vehicle does it. It isn't your fan, its the pressure difference between the high pressure area by the windshield, and the low pressure in the rear of the car, where the cabin exhaust air goes out. Basically you are just forcing air through the car at highway speeds, which you actually want. (assuming you like oxygen)
If you don't like it, either set your controls to send it to the floor, or to stop it entirely, put it on recirc. One thing to keep in mind though, if you are going down the highway with the fan turned off, the temperature control can provide heat, but the AC compressor will never turn. Turning the fan to 1 won't change the airflow any, but it will get a lot colder if you have the A/C turned on.
(just as a FYI, some manufacturers do actually spin the fan when you set it to the lowest setting. GM is notorious for this, there is an OFF button you need to hit, turning the fan all the way down doesn't stop it. The above still applies though)
Old 03-16-2012, 09:29 PM   #3
Dartholomew
Member#: 208771
2009 WRX
Very interesting, thanks for the detailed background. I've owned several other cars (including an '02 WRX) and driven dozens more, and honestly, my '09 WRX is the only car that I've ever noticed this on. I've got a long freeway drive tonight so I'm going to try the recirc trick.
And yes, I have noticed that the temp controls work just fine with the latent airstream even when the fan is set to off. If only the Sub didn't use temperature setting 1 as "ambient outside temp", and settings 2-10 as "hotter than hell."
fan on after engine's off RX Renesis Vancouver Impreza Club Forum -- VIC 15 06-19-2006 11:08 AM
please help weird fan cycling on off on off turbocolin Normally Aspirated Powertrain 9 06-13-2004 05:28 PM
WRX Climate Fan Assembly chrisdeaner Private 'Wanted' Classifieds 2 06-04-2004 09:50 AM
Texas Tech fan whacks off on sideline!! (No WARNING...) soundwave Off-Topic 9 01-05-2004 03:36 PM
Idle and fan on off? TallguY Warranty Issues & SOA Problems 4 02-08-2002 04:42 PM
