Old 03-18-2012, 03:50 PM   #1
Ptero
Member#: 124705
2001 Outback Sport
Default Timing belt issue. Help.
Car: 2001 Impreza OBS auto
the basics: Car died after driving one block, now won`t start. Cranks but won`t turn over. Any ideas?
This morning I started the car and drove 1 block before my car suddenly died. I popped the hood to see a tiny bit of smoke coming from the front of the engine where the belts are. The couple of belts in the front were not even warm so I can`t see them smoking. Only other belt left that I know of is the timing belt. I pulled off the timing belt cover expecting something to be fubard but the belt was in good shape and there was tension. Problem is, the car still won`t start. It cranks but won`t turn over.
Ptero is offline   Reply With Quote
Old 03-18-2012, 09:47 PM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Is it throwing any codes? Hows the connector on the crank sensor?
CosmoTheCat is offline   Reply With Quote
Old 03-19-2012, 11:03 PM   #3
Ptero
Member#: 124705
2001 Outback Sport
Took it to a garage and they found that one of the bearings failed on a pulley. Timing belt jumped more than a notch. They put in a new pulley and adjusted the timing belt only to find out that the engine was damaged. One of the valves is bent and the engine is running pretty rough.
Old 03-20-2012, 03:29 PM   #4
leecea
Member#: 37359
2003 WRX
That's rotten luck! How many miles on the pulleys?
leecea is offline   Reply With Quote
Old 03-21-2012, 12:59 AM   #5
CosmoTheCat
Member#: 3409
98 My FMIC
Timing belt jumped more than three notches most likely. I'd imagine the engine would run pretty rough with a bent valve.
I'd be curious to know how many miles on the pulley as well - is this a 105k mile service, or 210k? Errr, shoot that's what 160k kms or 320k kms? Or was it an age replacement instead of mileage?
Old 04-19-2012, 11:32 PM   #6
Ptero
Member#: 124705
2001 Outback Sport
Not sure how many miles on the pulley as I've only owned the car for a couple of years. The car has 245,000 kms on it.
New pulley was put on and the car runs really rough. At higher rpms it runs pretty smooth but coming to a stop, the car loses rpms and eventually stalls. Hard to keep the rpms up when stopping an automatic :P The shop figured its only running on 1 cylinder now. So the engine is toast. Not entirely sure if I'll put any money into the car at this point or just junk it.
URGENT! CAM TIMING HELP! timing belt issue krazykuppa Newbies & FAQs 25 10-18-2011 11:45 PM
car lost power mid-trackday. timing belt issue? HELP! dLo R6 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 03-05-2009 04:56 AM
help! 2.2 r&r & timing belt issues kimmae Normally Aspirated Powertrain 38 12-10-2008 10:51 AM
Help! Timing Belt Issues parkes Service & Maintenance 2 10-06-2008 04:00 PM
Desperatley in need of help with timing belt issue! Mally Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-19-2008 10:31 PM
