Old 03-18-2012, 10:25 PM   #1
Plainsman
Member#: 313761
Default Lift Points for Tire Rotate
Hello, first subaru. 2012 legacy 2.5
I see the pinch point lift places but I also was reading about a front lift point near the oil pan (old 06 thread) I would like to jack up the car and use the stands at the pinch points. I see near the oil pan what I assume is a tranny brace and as you go toward the oil pan there is another piece of steel. Can any of those be used to lift the vehicle? I have read previous models you can lift at the rear diff, is that still accurate for 2012?
Iv always owned pickups in the past with very evident frame rails, everything looks so delicate under here
Thanks much,
Robert
Plainsman is offline   Reply With Quote
Old 03-18-2012, 11:30 PM   #2
Plainsman
Member#: 313761
http://www.subaruoutback.org/forums/...ing-point.html
http://www.subaruoutback.org/forums/...-up-points.jpg
Found it, I was wondering about that chunk of metal sticking out of the skid. Thats the ticket, then hold it up with the pinch points.
what are the lift points for an '06 STi? GotoGroupbuy.com Tire & Wheel 10 03-31-2011 06:55 PM
Lift Points for Legacy Dagmar Newbies & FAQs 0 03-26-2007 01:03 PM
Lifting points for jack stands winkie711 General Community 38 12-04-2006 09:25 AM
Stock jack ok for tire rotation? xcdhridr Tire & Wheel 13 01-15-2005 10:30 AM
Where are the lift points for the engine? LiquidForce Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-12-2004 06:23 PM
