Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 08-20-2002, 05:37 PM   #1
Jon Cox
Member#: 8070
Default help...wiring autometer lunar series boost and egt gauge for lighting
anyone done this yet...ok, ive tested the gauges hooked up directly to the battery and they lit up...i did this b/c when i had them installed i couldnt get them to light up by any of the methods i found on this forum...i tried the 2pt connector behind the cd player...i tried the illumination fuse to the left of the steering column while it was grounded to the bolt the holds the a-pillar bracket...these did not work...i made sure i had the lights on each time and even tried every position you can put the lights in...nothin happened...anyone have any suggestions...the autometer lunar series gauges have a 12v pos wire and a ground for lighting purposes...
Any help is greatly appreciated...(i know ive posted this in other sections, but i havent got an answer that works yet...sorry)
Jon Cox is offline   Reply With Quote
Old 08-20-2002, 05:46 PM   #2
desiwrx02
Member#: 20168
02 wrx
black and blue all over
Try the clock. Pul it up, and read the labels on the back. Tap wires that are neccesary. Not too difficult
Ajay
desiwrx02 is offline   Reply With Quote
Old 08-20-2002, 11:42 PM   #3
WagonRX
Member#: 7480
WRB WRX 5 Door
VS2 12.9 @105 MPH-4EAT
Run the wire to the fuse box and jump it off the side after the fuse to protect the circuit. Just push the wire in the slot and insert the fuse back into place. The fuse will hold the wire from coming loose.
WagonRX is offline   Reply With Quote
Old 08-21-2002, 09:29 AM   #4
Jon Cox
Member#: 8070
i appreciate yalls help...i bought a multi meter yesterday and checked my 2pt connector at the cd player and it was getting power so i tried there again...wow, i actually worked...gauges are glowin now and i can dim them...i tried that fuse deal earlier and i guess i didnt use a good ground b/c it didnt work when i tried that about a week ago
thanks again....
Old 08-21-2002, 03:51 PM   #5
zacek
Member#: 19467
02 WRX
WR Blue
yup, remember that the dimmer is controller at the negative side of the current. This makes the installation a bit trickier. Therefore installing the A/F lunar gauge will be even more dificult since it shares the light with the power for the actual gauge.
zacek is offline   Reply With Quote
Autometer LUNAR SERIES ~BOOST and air/fuel ratio gauges.. JT's06sti Interior/Dressup/Audio & Security 1 06-09-2007 10:26 PM
FS: TO - Defi Blue Racer Series Boost and EGT gauges edvc520 Canada Region Private Classifieds 2 05-26-2007 10:22 PM
FS: TO - Defi Blue Racer series Boost and EGT gauges edvc520 Interior/Dressup/Audio & Security 2 05-26-2007 10:22 PM
FS: Autometer Lunar Series Boost gauge and pod kleinfreak North West Impreza Club Forum -- NWIC 4 08-04-2004 06:48 PM
autometer lunar series boost gauge wiring problem??? Jon Cox South East Region Forum 9 08-20-2002 09:13 AM
