Old 03-19-2012, 02:40 PM   #1
chancellor6869
Member#: 306289
1995 impreza-L AWD
red but will be white
Default swap question
ok my 95 just blew its ej18 and i was wondering if my tranny will work with the 20 or 22? or maybe the 25? cause im heading to the jy to pick one of these up if it does
chancellor6869 is offline   Reply With Quote
Old 03-19-2012, 05:42 PM   #2
overdrivex
Member#: 220581
2010 Impreza
camilia red
unless you want to do some wiring your better off just getting the same engine. unless you can find a phase 1 ej22 and just swap manifolds.
overdrivex is offline   Reply With Quote
Old 03-19-2012, 08:25 PM   #3
TOI
Member#: 238230
98 impreza sedan
yes, i have a EJ25 in my 93L using the original FWD tranny. should you? no unless like overdrivex said use a phase 1 ej22. the ej18 and ej22 use the same ecu or the ecu runs both or something like that.
TOI is offline   Reply With Quote
Old 03-26-2012, 12:20 AM   #4
D3F0
Member#: 265799
1988 Subaru RX TURBO
Do the ej22 conversion worth it in every way I have the same car with full manuals on everything let me know if you need any manuals or advice. Overdrivex and TOI are right same ECU and wiring the conversion is very easy however.
D3F0 is offline   Reply With Quote
Old 03-26-2012, 09:07 PM   #5
Wis
Member#: 284383
I had a 2.2 out of my wife car, and also have a 2.5 laying on the shop, the bell housings looked different to me, seemed like the 2.5 had more bolts, is this the case or do all subaru engines bolt to all tranny's?
thanks, had to get my 3rd post so i can start a post for my next project,
Wis is offline   Reply With Quote
Old 03-27-2012, 03:10 PM   #6
ManualOverAuto
Member#: 304662
2001 Impreza L coupe
Sedona red Pearl
What year do you have the manuals for the 2.2?
'97-'01?
ManualOverAuto is offline   Reply With Quote
Old 03-28-2012, 06:51 AM   #7
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Just to point out, any transmission that started on an EJ engine will bolt to any other EJ engine regardless of year, size or transmission type.
The only hiccup is when you use a phase 2 transmission against a phase 1 block because of the lower starter bolt. This can be remedied by welding/tapping a stud in place.
Old 03-28-2012, 02:00 PM   #8
D3F0
Member#: 265799
I spent 35 dollars for three days of access and downloaded all the ones i needed for all the cars i work on. Info is found on online http://techinfo.subaru.com/index.html
Its a tool for everyone provided by SUBARU. I have 93-2001
07 Light Tilting Feature Question swap question slim617 Electrical & Lighting 7 11-06-2010 11:36 PM
2002 WRX swap into 2001 RS swap question dtl1218 Subaru Conversions 14 08-13-2008 02:58 PM
dash swap and motor swap questions aka_tur Subaru Conversions 6 02-27-2007 06:21 PM
EJ20G front clip swap swap questions... 970subaru Subaru Conversions 24 01-01-2005 02:09 AM
