Old 03-19-2012, 04:10 PM   #1
tobylazur
Member#: 150289
2006 SV650, 05 CTSV
1972 Travelall
Default CEL code P0136...
Seems like on the CEL thread, when you get this code, you replace the rear o2 sensor.
So, where's the cheapest place to get a replacement? The dealer wants almost $300. Anyone have any experience with the sensors that you have to wire into the plug yourself?
vehicle is an 02 wrx wagon.
tobylazur is offline   Reply With Quote
Old 03-20-2012, 11:38 AM   #2
CRAZYHAWK
Member#: 198067
2009 IMPREZA 2.5i 4d
WHITE Premium
www.rockauto.com
2002 SUBARU IMPREZA 2.0L H4 Turbocharged DOHC : Emission : Oxygen Sensor Wiki Price Alternate
APWI Part # AP4310
Direct Fit; After Converter (Downstream) (Only 1 Remaining)
- Stocked in outlying warehouse--shipping delayed up to 1 business day
$32.99
Add Part
BECK/ARNLEY Part # 1564313
DIRECT FIT,Post Catalytic Converter (Downstream)
Choose: [Wholesaler Closeout -- 30 Day Warranty] (Only 3 Remaining) ($46.89)[Regular Inventory] ($87.99)
$46.89
Add Part See Options at Left
DENSO Part # 2344732 OE Style
Automatic trans.; Wire Length 21.26; DENSO is the O.E. Manufacturer; Downstream
$50.89
Add Part
DENSO Part # 2344446 OE Style
Standard trans.; Wire Length 27.20; DENSO is the O.E. Manufacturer; Downstream
$55.89
Add Part
BOSCH Part # 13538
Downstream; Automatic trans.
$64.79
Add Part
NTK Part # 24642
Post-Cat (Downstream); A/T
Post-Cat (Downstream); M/T
$69.79
Add Part
DELPHI Part # ES20219
Wrench Size: 7/8 in.; Actual OE Part; Rear (Downstream)
$75.79
CRAZYHAWK is offline   Reply With Quote
Old 03-20-2012, 06:09 PM   #3
Travisty
Member#: 241216
2000 Outback
2013 SWP BRZ
+1 for RockAuto on damn near everything.
Travisty is offline   Reply With Quote
Old 03-25-2012, 03:10 AM   #4
subie_lover
Member#: 294657
Yeah I ordered my exedy clutch set from there, that and the flywheel came out to the same price as the clutch set at autozone. Much better quality and cheaper price, can't go wrong there.
subie_lover is offline   Reply With Quote
Old 03-25-2012, 01:07 PM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
You can also try amazon.com for more common parts. Make sure the part #'s jive and see if you can go even cheaper.
p0136 CEL code. Can i disable it in Opensource? scOOtNsOOby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-17-2009 04:22 PM
APV1 isn't defeating CEL code P0136 cringeR AccessPort 5 10-08-2008 09:13 PM
cel code p0136 handfulopeter Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 09-05-2006 11:03 PM
HELP: where can I borrow a CEL code reader or get the code pulled for free? anonymous_wolf Vancouver Impreza Club Forum -- VIC 5 08-11-2005 02:40 AM
Any experience with Code P0136? suby ej25 Tri-State Area Forum 9 03-21-2005 10:47 AM
