Old 08-20-2002, 06:00 PM   #1
scoobyrex
Member#: 10174
2002 Impreza WRX
Platinum Silver Metallic
Default When to change spark plugs in WRX?
The dealer told me that I have 60,000 mile plugs in my car. The subaru website said to change them at 30,000 miles. Does anybody know the truth?
Thanks,
Eric
scoobyrex is offline   Reply With Quote
Old 08-20-2002, 06:04 PM   #2
STEALTH-WRX
Member#: 7822
Multi layer snot green
if you car is bone stock then do what the dealer says so if there are any problems blame it on them and warrenty it. other wise i personally change my plugs every 10k. you may also want to read this informations about spark plugs for your own benifit.
http://www.ngksparkplugs.com/techinf...s/overview.asp
STEALTH-WRX is offline   Reply With Quote
Old 08-20-2002, 06:20 PM   #3
scoobyrex
Member#: 10174
2002 Impreza WRX
Thanks for the info. The NGK article was very interesting.
Old 08-20-2002, 07:57 PM   #4
NotoriousWRX
Member#: 9026
The owner's manual is your friend!
NotoriousWRX is offline   Reply With Quote
Old 08-20-2002, 08:04 PM   #5
sorny
Member#: 10116
2002 WRX Sedan
Indeed. Manual says 60,000 miles. Wow, timing belt is 90,000, according to the manual, I'm used to 60K with Mitsu's.
sorny is offline   Reply With Quote
Old 08-28-2002, 02:23 AM   #6
HKxBlur
Member#: 22641
considering I've never seen this regarding a plug before, is it normal for the stock 2002 wrx center electrodes to be 'pointy' with a silver 'dot' on the underside of the side/ground electrode? They are labelled "PFR6G" and the center electrode is tapered to a point..
I've only worked with cylindrical center electrodes, and ngk split-type or similar, and have never seen this type of tip before on NGK plugs.. anyone?
HKxBlur is offline   Reply With Quote
Old 08-28-2002, 07:49 AM   #7
chuglobal
Member#: 10041
2015 WRX Limited CVT
ISM
Default Humm ...
Interesting ... I think I'm gonna read that page at work today.
chuglobal is offline   Reply With Quote
How to change spark plugs in an 05 Legacy 2.5 Gondi Service & Maintenance 3 12-11-2007 06:48 PM
when to change spark plugs? gingertooth Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-19-2006 05:03 PM
When to change spark plugs & what brand to use? Bradus Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 19 05-01-2004 01:53 PM
when to change spark plug wires rdmnks Service & Maintenance 6 02-28-2004 03:44 PM
When to change spark plug wires? Rusty the Scoob Service & Maintenance 11 05-17-2002 04:15 PM
