Old 03-20-2012, 03:21 PM   #1
steveomiami
Member#: 309883
Default injector/fuel rail question
ok so i ordered the rob tune and its on the way. i also ordered the sit yellow side feed injectors. I was told that i need either some adapters for the injectors or legacy gt fuel rails. i found some fuel rails and bought them. They look exactly the same as my current rails(i havnt seen mine with the injectors out yet since they are still on my car) is there a difference inside?
steveomiami is offline   Reply With Quote
Old 03-20-2012, 05:08 PM   #2
RallyColtTurbo
Member#: 16819
2002 MBP WRX, '98 OB
Three Gen 1 Legacy Turbos
I'm working on a few assumptions here....First, you have an EJ20G (or else you wouldn't need a Rob tune)...Second, your talking about an '96-'99 Legacy GT (those are the ones that work with the EJ20G).
If my assumptions are correct, then yes. Those are what you need.
RallyColtTurbo is offline   Reply With Quote
Old 03-21-2012, 01:02 AM   #3
steveomiami
Member#: 309883
yeah, sorry its a 1992 jdm wrx and i ordered the rob 500 tune which require the yellow sit side feed injectors. Which FPR do I use, the one thats on my car now, the one on the legacy fuel rail or should i get a decent adjustable one?
Old 03-21-2012, 04:14 AM   #4
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
ALA KaZaM!!
http://www.carldavey.co.uk/product.php?id=2
Or the legacy rails he was talkin about
im just using stock 20g fpr...but i guess a good aftermarket fpr would be better...
azn0boi04 is offline   Reply With Quote
Old 03-21-2012, 08:01 PM   #5
Subbiespeed
Member#: 276493
2000 Impreza EJ20G
SRP
i might be selling my tomei afpr with the matching gauge if the price is right
Subbiespeed is offline   Reply With Quote
EJ20G/EJ25D injector/fuel rail question JDMFLCL Pre-2002 Factory Turbo Powertrain 1 03-08-2010 04:25 PM
Fuel Injector And Fuel Rail Questions EvO KiLLeR 2005 Factory 2.5L Turbo Powertrain 1 07-10-2008 02:09 AM
03 wrx fuel rail vs. 05 sti fuel rail question cruzinWRX2 Factory 2.0L Turbo Powertrain 2 12-16-2007 03:08 PM
injector/fuel rail question happasaiyan Factory 2.5L Turbo Powertrain 1 07-17-2007 05:11 PM
FS: 96lb Fuel Injectors, Fuel rails, EIP Cat back exhaust, etc. PSI87 Private 'For Sale' Classifieds 34 05-06-2006 09:24 PM
Message Board Statistics All times are GMT -4. The time now is 12:21 PM.
