Old 03-21-2012, 12:09 AM   #1
dkwok
Member#: 296988
Default Rod knock/piston slap?
Hey everyone,
I have an '05 :92x:. To start, this is what my engine sounds like. http://www.youtube.com/watch?v=fTIth...ature=youtu.be
I have been shopping mechanics in my area they all believe its rod knock/ or a spun baring but after that i have been getting some mixed messages.
I will obviously need to rebuild or get a brand new block. but what else should i get done while they are in there?
The subietech i spoke with suggested I could rebuild with a 2.2 stroker kit along with Valve/head job, a master gasket set, hot tank the manifold, intercooler and oil pan, New 12mm sti oil pump or rebuild mine, and a New oil cooler. And maybe a new turbo too
Does this all sound right. I know its going to be an expensive fix, but i want to get it right while they are in there.
THanks.
dkwok is offline   Reply With Quote
Old 03-21-2012, 10:53 AM   #2
DDScooby
Member#: 161876
02 Impreza WRX
...IMHO after listening to that and experiencing a 2.0l engine failure myself a year ago, cut your aggravation, expenses and time by getting a brand new short block. A stock 2.0l short block is going to run in the ball park of $1750-2250, OR a 2.5(ej257) will be about the same and easier to find. NASIOC has a few very reputable vendors for such items. Of course send the heads out to a machine shop to have the heads worked over (this is a very reputable place on the East Coast (http://larryspower.com/)).
Then you will obviously need new ancillary parts and are a must and should not be skimped on. Turbo ($1029), Master Gasket set(~$250),11mm Oil pump($250), oil cooler(~$230)(http://www.subarupartswarehouse.com/) and possibly the timing belt/pulleys(~$260)(http://www.rockauto.com/catalog/raframecatalog.php) .
I'm fairly sure you will end up spending less going brand new rather than taking apart and repairing the old engine.
Good Luck!!
DDScooby is offline   Reply With Quote
Old 03-21-2012, 04:32 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
dont use the 12mm oil pump..its too much...and dont use any 5w30 oil..it all sucks
Old 03-21-2012, 04:32 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
double'd
Some knocking...rod knock or piston slap? mtcs Built Motor Discussion 41 12-03-2012 06:47 AM
06 sti engine knocking? piston slap? valves ticking? bboyjohn Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 06-15-2008 12:40 PM
So I blew my motor again: Rod knock? Piston slap? MarylandEcstasy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 44 05-17-2007 08:51 PM
Knock/Piston Slap?? wrxfactor Engine Management & Tuning 8 04-03-2006 06:11 AM
piston slap rod knock...engine overhaul baby_rs Bay Area Impreza Club Forum -- BAIC 3 12-25-2003 01:16 AM
