Old 08-20-2002, 08:12 PM   #1
moogooob
Member#: 15764
00RS -Dumb all over
A little ugly on the side
Default ECU reset, doesnt start on the first try?
MY00 RS with ganzflow:
When i reset my ECU, the car will not start up on the first try. It will crank, sound like its starting and then as soon as i let go of the key it dies. Try to start again and it starts right up.
Is this normal or expected after an ECU reset?
Background info on how i reset the ECU:
Cold engine--->disconnect the neg terminal and let sit for 20 or so minutes. Reconnect the neg wire and turn off alarm wih remote. start car with just a key turn. let warm up 15 minutes or so. Turn off car, turn on car, go for drive of redline a few times in first and second.
I hav't had any probles or CELs, just curious on this.
Thanks in advance for your comments.
Robb
moogooob is offline   Reply With Quote
Old 08-20-2002, 08:32 PM   #2
RawCode
Member#: 3115
2002 Impreza 2.5RS
When I did an ECU reset for my RS, it had a hard time idleing at first. It seems to have eventually re-learned how though which is good cause it would almost die at stop lights.
I think it would just be part of the learning process. Remember to be a good teacher and take your car on many long sweeping runs!
RawCode
RawCode is offline   Reply With Quote
Old 08-20-2002, 09:49 PM   #3
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Actually, if it DOESNT stall out...it wasnt done right. It's SUPPOSED to stall on the first try.
If the engine is completly cold (overnight sitting) then the engine should have no problem stalling out, but if its even just a little warm it wont stall and then it doesnt learn the initial A/F ratios right.
DDMan is offline   Reply With Quote
Old 08-21-2002, 01:44 AM   #4
moogooob
Member#: 15764
00RS -Dumb all over
Thanks DDMan.
Old 08-21-2002, 01:45 AM   #5
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
Enjoy your ganzflow.
Marcin is offline   Reply With Quote
I got the seatbelt mod to work on the first try!!!! 06 TR chirp the 1-2 Newbies & FAQs 6 05-05-2006 04:01 PM
Anyone else's WRX not start on the first time occasionally? vitaminwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 03-14-2005 06:50 PM
ECU Reset, is itOK on STI Jerry C Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-03-2003 11:38 PM
ECU reset w/o taking the battery out. tmat3 Normally Aspirated Powertrain 9 11-02-2001 04:24 PM
('93-'01) If I do an ECU reset will it erase the datalogging? aarneson Impreza Forum 7 06-26-2001 10:47 PM
