Old 03-21-2012, 07:46 PM   #1
stirs25
Member#: 181779
Default power fc and bov change?
can I run power fc (ECU which runs off MAF) and tune it successfully with atmospheric dumping bov (non recirc one)?
thanks all
stirs25 is offline   Reply With Quote
Old 03-21-2012, 07:55 PM   #2
Subbiespeed
Member#: 276493
2000 Impreza EJ20G
SRP
my ej20g has power fc and i have a hks super and it runs fine minus the bad sensor i have making it idle at 2k
Subbiespeed is offline   Reply With Quote
Old 03-21-2012, 08:18 PM   #3
stirs25
Member#: 181779
which sensor? are you also running the stock EGR and the fuel vapor solenoid? i'm planning on taking it out and blocking the port off as well. someone told me that if you run power fc with non recirc BOV, it'll run too rich. i was wondernig if that's true..
Old 03-21-2012, 08:27 PM   #4
Subbiespeed
Member#: 276493
2000 Impreza EJ20G
SRP
maf is the aa160, only mods on the motor is front mount intercooler, turbo xs mbc, hks ssqv, downpipe and catback, i had a tomei afpr but i took it off, and the turbo is a vf28 and the motor is a 94 wrx...im running a lil rich but thats not because of the hks...between me and my buddy we've had it on there since we put the motor in and had no issues but then again i don't have a wideband so
Impreza Apexi Power FC and FC Commander EM snowcrzy Engine/Power/Exhaust 12 04-05-2007 11:29 PM
Apexi Power FC and idle scoobyimprza Pre-2002 Factory Turbo Powertrain 10 09-01-2006 10:42 PM
Power FC and MAF Danny@VIPtuning Engine Management & Tuning 6 08-17-2006 03:28 PM
Apexi Power FC and Commander annointed Factory 2.0L Turbo Powertrain 36 11-28-2004 09:43 PM
Apexi Power FC and Commander........ redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-10-2002 01:08 AM
Message Board Statistics All times are GMT -4. The time now is 09:20 PM.
