Old 04-01-2012, 03:54 PM   #51
jazzy_JAE
Member#: 283942
2008 Impreza WRX STI
Originally Posted by Trudd84 View Post
*****IF YOU USE ONE OF THESE TRI LEDS FOR THE ODOMETER AREA, IT IS 3X BRIGHTER THAN THE REST OF THE GAUGES! i AM SWITCHING TO A SINGLE LED AS IT IS VERY OVERWHELMINGLY BRIGHT AT NIGHT. THE THREE BULBS ARE GREAT FOR EVERYTHING ELSE.*****
Pics included:
since you say that it's too bright at night, i'm going to try the "super high power 1 watt super charged led bulb" on the website the OP posted. i'm ordering them now, and will post pics when installed
jazzy_JAE is offline   Reply With Quote
Old 04-03-2012, 12:04 AM   #52
dptubi
Member#: 304561
2004 Outback Sport
Just bought a set of the blue ones. Can't wait it should match great with blue headunit i have. At some point I want to get to the cluster and the door switches.
dptubi is offline   Reply With Quote
Old 04-10-2012, 02:51 PM   #53
jazzy_JAE
Member#: 283942
Originally Posted by RSXNTN View Post
The gauge cluster is pretty much the same process, but is way more time consuming and a royal pita!
did you remove the green micro dot film off of the back of the gauge faces? when i put my red leds in, they were very dim, and i assume it had something to do with that green backing
Old 10-25-2012, 05:46 PM   #54
KFREX
Member#: 330609
2004 Subaru WRX
Java Pearl Black
I would also like to know the answer to this question
KFREX is offline   Reply With Quote
Old 10-26-2012, 12:03 AM   #55
castper
Member#: 300342
Pretty sure you have to to make them look good. I'm still debating on doing this. I have a feeling I will mess up a needle and break the cluster lol
castper is offline   Reply With Quote
Old 10-26-2012, 02:24 PM   #56
Redbolt04
Member#: 329226
2002 WRX Wagon
+1 to this question. I already went through with the HVAC using a 10" led ribbon and it turned out great. Looking to do the cluster next. If a decent result can be had by simply switching bulbs count me in!
Redbolt04 is offline   Reply With Quote
Old 10-26-2012, 03:06 PM   #57
dirtwarrior
Member#: 213437
2004 WRX Wagon
you need to sand down the film to make the instrument cluster look good.
dirtwarrior is offline   Reply With Quote
Old 10-28-2012, 11:49 PM   #58
KFREX
Member#: 330609
2004 Subaru WRX
Java Pearl Black
I ordered 20 of the same bulbs as the OP. I chose green bulbs hoping they makes things still look stock, just brighter and crisper. I hope they make things look more neon green than teal. I will update you guys with pics after it is done, should be easy since I am just replacing bulbs, no sanding.
Old 10-29-2012, 03:39 AM   #59
scubynoob
Member#: 276157
2006 WRX sedan
^ in for results. I was interested in doing the same thing.
scubynoob is offline   Reply With Quote
Old 11-24-2012, 05:19 PM   #60
rotheee
Member#: 291964
2003 WRX
quick questions:
1) So in order to get rid of the greenish film or anyother color on the back side of the cluster gauges you need to sand them down?
2) If i pull the needles off will the readings be messed up after wards?
rotheee is offline   Reply With Quote
Old 11-24-2012, 05:47 PM   #61
rotheee
Member#: 291964
2003 WRX
Nevermind!!! DO NOT TOUCH the needles. also i just put my cluster back in my car now my parking ligts are off and won't turn off? WTF
Old 11-24-2012, 05:47 PM   #62
emazz104
Member#: 281811
04 WRX
World Rally Blue
http://www.superbrightleds.com/morei...edge-base/228/
Anybody used those specific bulbs in the cluster? I don't want any hot spots like I had with my HVAC lights.
Originally Posted by rotheee View Post
quick questions:
Yes, and I believe so yes.
I know if you bump them it will mess them up.
I don't know if there is a way to remove them without messing them up.
You shouldn't have to in order to sand off the green film.
(I may be wrong, I researched this for a while when I had my last car but decided it was too much work, now I'm looking into it again.)
emazz104 is offline   Reply With Quote
Old 11-24-2012, 05:58 PM   #63
rotheee
Member#: 291964
2003 WRX
yeah needless to say i moved my needles and now they dont work check out this video. Pretty good video! will show you how to get it all apart!
Old 11-27-2012, 02:44 PM   #64
Rickybobbyn1
Member#: 339067
I recently went about changing the color of my Evo bulbs but got lazy and used paint markers from walmart, works just as good! The bulbs haven't gotten hot enough to melt the paint off, so far so good
Rickybobbyn1 is offline   Reply With Quote
Old 11-27-2012, 09:16 PM   #65
rally kid2174
Member#: 334187
05 subaru RS
black soon will be paintd
was this a RS gauge cluster or aint the cluster green so if i put blue leds behind my gauges it will light up blue?????????????? and how many leds 4 the gauges and the hvac cos im going 2 do this mod
rally kid2174 is offline   Reply With Quote
Old 01-22-2013, 01:59 PM   #66
ABeastinWRX
Member#: 239469
2004 WRX
PSM for now ;)
Worked a lot better for me since I have the manual HVAC controls it's a bitch to take out.
ABeastinWRX is offline   Reply With Quote
Old 01-23-2013, 11:07 AM   #67
kevin85193
Member#: 145900
2003 wrx wagon
just ordered 6 bulbs for now. Couldn't justify spending $80 on bulbs right now.
shouldnt of sold my 04 STI cluster lol.
also found this link for taking the cluster apart
kevin85193 is offline   Reply With Quote
Old 02-18-2013, 09:56 AM   #68
subyrules04
Member#: 73366
04 WRX /Cobb Stg 2
4EAT Platinum Silver
I just ordered the same tri-leds from LEDLIGHT.com for like half the price. plus I ordered some singles for door buttons etc. free shipping if order is over $50
subyrules04 is offline   Reply With Quote
Old 02-21-2013, 03:06 PM   #69
rally kid2174
Member#: 334187
05 subaru RS
Default replying 2 ur thread
how may lights are there behind the hvac cus i want to do the same thing and would want to know how many leds to buy
Old 02-21-2013, 10:37 PM   #70
castper
Member#: 300342
2 in the bugeye
Old 02-22-2013, 08:08 AM   #71
wirebiter
Member#: 327574
Did my cluster, with blue behind gas and temp white Led strip behind tach and speedometer, 1 red led at redline. Is there any way to change light in odometer?
wirebiter is offline   Reply With Quote
Old 03-28-2013, 04:13 PM   #72
castper
Member#: 300342
I know it's been a while but you can, you just need to peel off the inversion tape stuff on it and then replace it with another color
*OFFICIAL* Space Trek Thread. Live long and proper: the droids aren't looking for you Protege Menace Off-Topic 8797 04-03-2012 09:29 AM
2011 STi with HID kit in driving lights SubeySTi2011 Interior & Exterior Modification 27 03-21-2012 11:11 PM
FS : 17x8 Gold Wheels and Dunlops KY OH IN ImprezaSaurusREX Wheels/Tires 10 03-21-2012 09:02 PM
FS : skid plates and map light JENowman Exterior/Styling 2 03-21-2012 01:01 PM
FS : Prodrive Round Tip Axle Back - New In Box DJHiRoller NESIC Private Classifieds 10 03-21-2012 08:35 AM
Message Board Statistics All times are GMT -4. The time now is 05:12 PM.
