Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 03-21-2012, 07:13 PM   #1
DDScooby
Member#: 161876
02 Impreza WRX
Default Odd code after plugs changed
I'm running a fairly aggressive tune in my hybrid motor. I changed the spark plugs today and it wasn't the stock iridium plugs, but I put in the NGK Copper "v-power" cheapos.
Soon after I started it up CEL came up and had the code read at Advance. P1130 (A/F sensor malfunction). Are the plugs causing this or is the sensor really bad?
I'm guessing plugs.
DDScooby is offline   Reply With Quote
Old 03-21-2012, 09:19 PM   #2
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
im guessing you borked something....like on the 1-3 side....like where the o2 sensor harness is supposed to be attached to the #3 coilpack
is that the only code coming up???
Old 03-21-2012, 09:35 PM   #3
DDScooby
Member#: 161876
02 Impreza WRX
Yes that is the only code...checked it three different times. Cleared it each time and same code came back.
cracked ceramic neck or improperly gapped plug?
Old 03-22-2012, 12:48 AM   #4
Uncle Scotty
OK buy Nates beans
it almost certainly isnt a plug issue...it IS almost certainly a problem with the front o2 sensor
Click to View Search Results for P1130 - Google Search P1130 - Google Search
Old 03-22-2012, 02:09 AM   #5
DDScooby
Member#: 161876
02 Impreza WRX
I guess I'm sorta confused that a sensor is fine the day before, change spark plugs, then sensor bad. hmmm
Guess I was hoping for a $25 fix rather than a $130 fix...
Guess its a $155 fix...ordered the plugs and sensor
...This is a stretch, but would having a car tuned with a dirty and gummed up MAF sensor, then cleaning the MAF after the fact have the same result? I gave the MAF a good cleaning when I changed the plugs. My guess is not; however, improbable is not impossible. -and I would think the car's learning curve would compensate after a ECU reset, which I did as well. -I could also be over thinking this too. lol
Old 03-22-2012, 02:48 PM   #6
DDScooby
Member#: 161876
02 Impreza WRX
Definitely isn't the plugs. Sheathing around the 4-wire harness was melted through... -The wires themselves weren't burnt, or at least from what I could see. But I'm putting my money ($108 for a new sensor to be exact) on pure noob error and not making sure the wire was out of the way of the passenger side bank.
ho hum, oh well. -lesson learned.
Thanks for the input UncleScotty!!
low idle after plug change?!! binkman88 Normally Aspirated Powertrain 3 02-14-2009 09:29 PM
power seems down after plug change? ClevisR6 Service & Maintenance 10 07-02-2008 05:15 AM
CEL After Plug Change Infra_red Service & Maintenance 7 06-08-2008 10:31 AM
Engine ticking after plug change BlkTS02 Normally Aspirated Powertrain 3 03-04-2005 04:26 PM
Odd code after Stage 4 install CpnNeeda Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 07-27-2003 07:06 PM
