Old 03-22-2012, 01:05 AM   #1
PureTorque
Member#: 157281
07 VF39'd WRX TR
WR Blue
Default 05 Sti engine swap into 02 Wrx
Hello everyone,
Well with over 4 hours of searching and reading, I still have not found my answers. I came across a deal of a 05 sti engine and want to know exactly that must be used and done on the wrx/sti. Reviewing psychorunner/punkrocksailor/ and another member who swapped in a 07 sti drivetrain into his 02, there are still holes to fill in. I just finishing swapping in a 06 wrx transmission and will be running this with the Sti motor. From this, I will not be using the dccd. The motor will be coming with
Chassis/Dash Harness
Engine Harness
Complete 05 Sti engine
05 sti Ecu
Ignition/key and immobilizer
Gauge Cluster
DBW Pedal
From researching there are a few things that I am skeptical on.
1. Heating and AC. Since I will be changing the dash harness, will I need the complete HVAC system under the dash? Will I need the HVAC controls?
2. Fuel Pump. Knowing that my fuel filter is in my engine bay, and the sti is in the fuel tank. Will a fuel sending unit be necessary? Also I am guessing the plugs on the 05 and 02 are different for the sending unit?
3. ABS Module. Reading psychorunner thread, it was noted that the abs module is different. Will I need the 05 sti or can I simply wire my 02 module into the new 05 sti harness.
4. Window controls. Will my 02 door harness plug and play into the new 05 sti chassis harness?
5. Wiring. Using my 06 transmission/diff, will anything need to be spliced and rewired during the swap?
5. Additional Parts? Is there any other parts that will be needed from the sti? here is a list of parts that are in question
sti Steering Column
sti HVAC switches/heater box/ac box
sti ABS module
sti door harness(if necessary)
sti steering wheel( because of the air bag)
sti wiper motor
Sorry for the million questions. These are my concerns before diving into the swap. All the other members who have completed the swap, had a donor car to take the parts from. I will be driving 6 hours to get the motor/parts, so I would only like to make one trip. This thread is also useful to finally rest the question of what is needed to swap this motor into this car. Many other threads started had a question or two, with no answers/replies. Any help would be appreciated, especially from the veterans who have completed such a swap. I understand this has been topic has been discussed many times, but I would like to clarify all these concerns for myself and others.
PureTorque is offline   Reply With Quote
Old 03-23-2012, 12:18 AM   #2
RexWagonWA
Member#: 221945
Default swap
you may want to check out iWire. They make conversion harnesses.
Do you have to be inspected and pass emissions?
RexWagonWA is offline   Reply With Quote
Old 04-04-2012, 08:58 AM   #3
3grst01
Member#: 300218
you can use your ej205 heads directly on your 257 just get new gaskets studs and have the combustion chamber smoothed out smoothly to the inside of the new gasket circle on each heads comb. chamber so its not a flat spot in your combustion chamber. You can also get some nice cams and re do the valves if you want. Then all you need is a tune.
3grst01 is offline   Reply With Quote
Old 07-07-2012, 06:41 AM   #4
boostinsubie
Member#: 177529
2002 wrx
yellow
Did you get your answers. I'm just about to finish up the same type of swap I came across the same issues.
boostinsubie is offline   Reply With Quote
Old 07-16-2012, 06:33 PM   #5
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Door harnesses, Door switches, door cards & inside door handles ( or merge the door harnesses )you'll need to merge the /rewire the headlights,foglights & markers also
sense of nature is offline   Reply With Quote
Old 07-18-2012, 04:39 PM   #6
keymy
Member#: 326562
Default hum
sounds good
keymy is offline   Reply With Quote
Need Help:Questions on 05 Sti Rack swap into 02 Wrx Slo_Buggy Brakes, Steering & Suspension 6 01-14-2011 01:37 AM
08+ WRX Engine Swap into 02 WRX KpT KiM Newbies & FAQs 4 08-07-2010 10:09 PM
05+ auto HVAC swapped into 02 WRX Loomin Subaru Conversions 0 11-23-2008 03:34 AM
05 STi Engine swap into 04 WRX ?s srREXed Subaru Conversions 10 06-04-2008 12:25 AM
05 STI Engine Mounts into 02 WRX? sleepinsuby Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-30-2005 05:17 PM
