Old 03-22-2012, 08:51 AM   #1
T-WRX21
Member#: 212098
2011 WRX STi
PBP (Blurple)
Default A/C help on 2002 wrx
So I went out to recharge my A/C system on MY02 wrx and not too long into the process, freon started leaking out of my low side hose that connect to the compressor. It was leaking right where it meets the compressor so I thought it was missing an o-ring of some sort but when I put one in there it still leaks. Any suggestions? I don't think my compressor is bad bc before I start turning up the pressure in the system, my compressor engages but then it leaks shortly after
T-WRX21 is offline   Reply With Quote
Old 03-22-2012, 12:43 PM   #2
Rally Monkey
Member#: 36310
03 WRX Sedan
Originally Posted by T-WRX21 View Post
Any suggestions?
Take the car to a shop that does AC work, and stop venting refrigerant to the atmosphere.
Rally Monkey is offline   Reply With Quote
Old 03-24-2012, 07:47 AM   #3
T-WRX21
Member#: 212098
2011 WRX STi
PBP (Blurple)
im not stupid, I know not to vent refrigerant into the atmosphere but how was I supposed to know my A/C was leaking without putting refrigerant into it in the first place.
Old 03-24-2012, 01:07 PM   #4
Rally Monkey
Member#: 36310
03 WRX Sedan
im not stupid
No, you are not stupid and I do not enjoy insulting people. This is my observation:
"how was I supposed to know my A/C was leaking"
"So I went out to recharge my A/C system"
Old 03-24-2012, 01:11 PM   #5
Rally Monkey
Member#: 36310
03 WRX Sedan
Well maybe...just a little, but that was not my intention here.
Old 03-25-2012, 12:52 AM   #6
T-WRX21
Member#: 212098
2011 WRX STi
PBP (Blurple)
Ok, before you start quoting *****, read what I wrote in the beginning. Im pretty sure I stated that I went to recharge my a/c before I knew it was leaking, otherwise why would I charge a system that's already leaking and when I tried fixing the issue it was still happening so I gave up bc I didn't want to VENT REFRIGERANT INTO THE ATMOSPHERE. So if anyone here is the dumba** it's you my friend. Also, that was my intention to insult you, bc your an idiot. Get the hell out of my thread so someone with common sense can help me.
Old 03-25-2012, 03:22 AM   #7
Rally Monkey
Member#: 36310
03 WRX Sedan
Please fix your AC any way you see fit ....so you can CHILLLL.
Old 03-25-2012, 11:36 AM   #8
Rally Monkey
Member#: 36310
03 WRX Sedan
your an idiot.
No, you are the foul idiot.......who can't fix her AC.
Old 03-27-2012, 10:41 PM   #9
SilverBOXER4
Member#: 119934
2015 WRX Limited
CWP
I had the same problem a year ago. Make sure the oring is not smaller than stock. When installing make sure it tugs and snap in just so you know it's tight in there. Torque it down but do not over tighten. Good luck with the fix.
SilverBOXER4 is offline   Reply With Quote
Help a Newb out, Questions on 2002 WRX 02electricblue Newbies & FAQs 4 03-01-2011 08:59 PM
Will 2002 sti stuts with lowering spring fit straight on 2002 WRX wagon? Martin.dean1981 Brakes, Steering & Suspension 2 01-23-2011 11:47 AM
VF48 Turbo on 2002 WRX help danchiiik Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 12-16-2010 04:08 AM
Link 44s switching to Reflash on 2002 WRX 2.5, fuel problem, help! fc3swrx Engine Management & Tuning 0 03-30-2009 08:18 PM
help installing hella 500 fog lights on 2002 wrx? PARAMEDIC Interior & Exterior Modification 2 01-21-2002 08:11 AM
