Old 03-22-2012, 04:12 PM   #1
chancellor6869
Member#: 306289
1995 impreza-L AWD
red but will be white
Default ej18 cam question
hey guys whats the biggest cam i can do for my ej18? im building it up thanks.
chancellor6869 is offline   Reply With Quote
Old 03-22-2012, 04:43 PM   #2
tairyhesticles
Member#: 311614
1995 WRX
Well are you building it up or swapping it like you said in your previous thread? Maybe you should come up with a solid plan before buying expensive race cams for a blown engine. You can run 272-280's, with tuning and tight valve springs and titanium retainers. But that's not "size", thats the degree of the lobe.
tairyhesticles is offline   Reply With Quote
Old 03-22-2012, 04:56 PM   #3
chancellor6869
Member#: 306289
1995 impreza-L AWD
im trying to see what options are out there....cause im looking at a legacy with a ej22 and another impreza with a ej18, but i think ive made up my mind and im going to go with another ej18 block and build on it
Old 03-23-2012, 12:00 PM   #4
OddBallRacing
Member#: 136429
1996 ImprezaBrighton
Gawdawful Green
I just swapped EJ22 heads onto my EJ18 block though I do believe that there are *some* cam swap options. Penty of info out there to be had... Good Luck!
OddBallRacing is offline   Reply With Quote
WTB: EJ18 cams or heads (NJ) Junglefbs MAIC Private Classifieds 0 09-25-2009 12:10 PM
EJ18 Cams in EJ25 Heads pilfflip Subaru Conversions 1 07-02-2006 11:32 PM
Ej18 cams in...???...there's a high idle pilfflip Subaru Conversions 0 06-11-2006 05:29 AM
EJ18 turbo questions... 93L-RS Normally Aspirated with bolt-on Forced Induction Powertrain 11 06-05-2006 12:01 AM
EJ22 > EJ18 cam conversion question pilfflip Subaru Conversions 1 05-22-2006 06:09 PM
