Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Suspension/Brakes/Handling
Old 03-22-2012, 07:34 PM   #1
subysouth
Member Sales Rating: (10)
Member#: 5039
2007 Outback XT
Grey 5-speed
Default Front and Rear vented rotors, 294x24mm and 290x18mm
Up for sale are front and rear pairs of vented rotors. The source for these was a JDM B4 but these are the same size front and rear rotors that come with the non-Brembo 4/2 pots found on the 05 WRXs et al. These came on the B4 with 2 pot fronts(I have a pair of these for sale in another ad) and single pot rears. The 2pot fronts are identical to the 02-04 WRX fronts which can be found on several other subies and the single pot rear calipers can be found on the 05+ Legacy GTs. I think even some aftermarket companies use these rear oem rotors in their kits. So you have several options for squeezing these.
The rotors were off an extremely low mileage B4 - 50km was the quote and that appears right based on wear which is negligible. When I got them in, I cleaned and scuffed the top surfaces and sprayed them with VHT extreme temp manifold paint which was then baked on in the oven per the VHT directions. I do this with a lot of my rotors because the oem hat paint tends to rust through very quickly. The color is kinda a grainy metallic gray. The pad cuts through the paint in no time at all and bonus the wear path is identical to your swept area - no rusty untouched areas.
65 shipped for the fronts and 75 shipped for the rears. Thanks for looking.
ss
subysouth is offline   Reply With Quote
Old 03-26-2012, 10:46 AM   #2
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
TTT
ss
FS : Brembo Calipers Fronts & Rears with rotors, pads, and kit ImprezaWrx9 Suspension/Brakes/Handling 18 06-26-2011 03:07 AM
06 STI Brembo Front and Rear Calipers, Rotors, and Pads akito Suspension/Brakes/Handling 2 06-19-2010 05:19 PM
Legacy GT Front and Rear Brakes Calipers, pads and Rotors, Subaru Red 4pots lazybummm SCIC Private Classifieds 11 12-01-2009 03:53 AM
06 wrx four pots front and rear with rotors and hubs ldscamaross Suspension/Brakes/Handling 8 01-25-2009 01:59 PM
Legacy GT Front and Rear Brake Calipers, pads and Rotors, Subaru Red 4pots lazybummm SCIC Private Classifieds 0 10-29-2008 06:00 PM
