#1 |
Member#: 246919
Vehicle:2007 WRX STI Black |
SO i was driving to the car wash and gave the car some gas in 2nd to make a light and before i could go into the third the car shut off gauge cluster was off but my boost, oil psi, and AFR stayed lit up but wasnt reading anything! car turned on fine and drove fine afterwards and after the wash drove fine even under load. Any suggestions as to what it was??
#2 |
Member#: 84680
mods?
#3 |
Member#: 246919
Stage 2: turboback, catless, spt intake, lightweight crank pulley, LW fly wheel act clutch...sums it up drivetrain wise
#4 |
Member#: 171948
Vehicle:08 wrx prem sedan vf52 swap. bilstein susp |
do you have a blow off valve??
#5 |
Member#: 67
SCIC
Vehicle:1999 Outlasting the competition. |
Do you have a lot of crap on your keychain? I had a customers car years ago that would shut off after random bumps etc. we tracked it back to having a lot of junk on the keyring.
#6 |
Member#: 246919
No blow off valve and I wouldn't say alot of crap car key and remote and gym tag..did hit a solid bump/ rail road tracks
#7 |
Member#: 197764
NESIC
Vehicle:02 WRX Stage DD PRND 01G |
It was the popo with their advanced technology, they saw you try to make the light.
#8 |
Member#: 246919
#9 |
Member#: 204358
SCIC
Vehicle:01 2.5RS W/ EJ257 Black |
What was your fuel level like??? you weren't below 1/4 were ya?
#10 |
Member#: 16200
Vehicle:OK Houston we have an Uncle |
check the battery cables...make sure they are tight
#11 |
Member#: 246919
#12 |
Member#: 16200
cars just dont 'shut off'....im betting the battery cables are not 'fine' or there is another electrical issue related to poorly done wiring, somewhere
#13 |
Member#: 271681
NESIC
Vehicle:2013 WRB Subaru WRX AJW Performance |
#14 |
Member#: 246919
any other thoughts? a friend said it could be a vacuum line but wouldnt my boost gauge be off if it was that?
#15 | |
Member#: 16200
![]() d0000000000000d....there have been NUMEROUS reports of battery cables being lose and causing this theoretically.....taking the battery cable off the battery wont cause it to die....but an intermittent connection does it no good at all but....it has happened where the ONLY thing that people have changed is tightening the clamp on the terminal to the battery and the issue was resolved |
#16 | |
Member#: 487
TXIC
Vehicle:1998 /2005 STunIcorn Acadia Green RS-T |
same symptoms occuring to my boss's 09 acura, loose batt terminal was cause. |
| Thread Tools | |
| Display Modes | |
| Ver. 5 Sti - Motor turns off while driving ?! | Mattcheww | Factory 2.0L Turbo Powertrain | 8 | 04-26-2010 02:47 PM |
| car shuts off while driving | reeksti | Service & Maintenance | 5 | 03-07-2006 10:40 AM |
| Help, engine turning off while driving | timmyduboy | Service & Maintenance | 3 | 10-18-2005 02:27 PM |
| Car shuts off while driving (post for a friend) | BlueTDimly | Normally Aspirated Powertrain | 4 | 12-30-2002 11:25 AM |
| car shuts off while driving.... | sethiscope | Service & Maintenance | 3 | 03-11-2002 02:36 PM |
