Old 03-24-2012, 09:15 AM   #1
steveomiami
Member#: 309883
Default horn problem
1992 JDM WRX horn isn't working. I pulled the switch and it works, i checked both horns and they work. where is the fuse or relay at? If i can't figure this out how do i rewire it?
steveomiami is offline   Reply With Quote
Old 03-24-2012, 09:51 AM   #2
steveomiami
Member#: 309883
I have no blown fuses, with both horns connected my + and - have continuity with one disconnected they don't. Looking under my dash I can tell there has been some rewiring of who knows what done. what should i do?
Old 03-24-2012, 10:12 AM   #3
steveomiami
Member#: 309883
oh, and does the stock horn switch complete the ground or is it hot? it is a nardi steering wheel with a nardi switch
Old 03-28-2012, 02:20 AM   #4
steveomiami
Member#: 309883
come on guys i am sucking with electronic bugs
Old 03-29-2012, 01:16 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
There is a horn relay. My other cars horn didn't work either. But it wasn't my relay or fuse or switch, I just kinda have up on it and started yelling at people.
But i believe the horn relay has a red cap and is located by the driver where all the other fuses and relays are. U can always rig up a separate switch. with a momentary switch from Oreillys....not autozone.
azn0boi04 is offline   Reply With Quote
hella horn problem asherbo Interior & Exterior Modification 6 11-17-2011 12:13 AM
Horn problem paul_leo Newbies & FAQs 6 11-21-2006 11:00 AM
Horn problem. GC_Anthony Electrical & Lighting 4 09-26-2006 12:28 PM
Help! Odd horn problem. ScoobyDoobieBlue Electrical & Lighting 2 04-06-2006 02:48 AM
Heh... Air horn problem solved (Pooh) speedybrent Texas Impreza Club Forum -- TXIC 2 05-27-2001 05:12 PM
Message Board Statistics All times are GMT -4. The time now is 07:03 PM.
