Old 03-24-2012, 10:40 AM   #1
chithead
Member#: 312018
2014 WRX Hatch
Default 2007 Subaru WRX Wagon - all JL Audio build
I thought about waiting until the install was finished to do a build log, but that's just not my style. When I said it was going to be an all JL Audio build, well I wasn't joking. If they make it, I'm using it. I want just a simple, dependable daily driver setup, and this is what I come up with:
JL Audio C3-650 Component Set
JL Audio 12W7 Subwoofer
JL Audio Slash 300/2
Jl Audio Slash 500/1
JL Audio XD-PCS4-2B Dual Amplifier Wiring Kit
JL Audio XD-PCS4-1B Single Amplifier Wiring Kit
JL Audio XD-BTS Battery Connector with red logo for positive terminal
JL Audio XD-BTS Battery Connector with black logo for negative terminal
JL Audio XC-BCSC16-25 16ga Speaker Wire (two of these)
JL Audio XB-CLRAIC2-18 RCA Interconnects (pair of these)
JL Audio XA-SWA-SX16 16ga Speaker Connectors
JL Audio XD-RT8-4PAK 8ga Ring Terminals
JL Audio XD-RT4-4PAK 4ga Ring Terminals
JL Audio XD-MAXI-40 40amp Maxi Fuse
JL Audio XD-MAXI-50 50amp Maxi Fuse
I have some CLD tiles and Butyl Rope from a previous install, and will be applying more of that roof rubber that worked very well in my Ram R/T install.
chithead is offline   Reply With Quote
Old 03-24-2012, 10:41 AM   #2
chithead
Member#: 312018
2014 WRX Hatch
I know lots of people are asking which radio will I be using... well it's already installed!
Factory Clarion PF-2868A-A/B 6-disk CD/MP3/WMA Player with Auxiliary input ready to rock and roll! I found out the factory harness only has four outputs, and that the tweeters are a simple passive crossover tapped directly into the front door woofers. So I'll be using a DIY adapter between the factory radio and the factory harness to get the signal from, and taking it straight to the JL Slash amps. They can handle a high voltage input, like from a factory radio, so we'll try this route first, and then go from there.
Here is the adapter I built to handle this task:
Radio input harness ready to go:
Techflexed the factory speaker inputs for now, I plan on running all new wires. I shortened the connections on this side to try and make the adapter as small as possible inside the dash:
And here it is soldered, heatshrinked, and ziptied for a neat and clean look:
Old 03-24-2012, 10:41 AM   #3
chithead
Member#: 312018
2014 WRX Hatch
Here is how I plan on hiding the distribution block, yet still making it easy to access the fuses in case of maintenance:
I drilled a hole in the cover, and installed a simple bolt with two nuts to lock it down, then screwed on a magnet logo from a 10W6V2 subwoofer. This will allow me to hide the distribution block underneath it for a real tidy trick, yet still allow easy access in case of emergency. I'll probably light this with some LEDs just for showing off.
Old 03-26-2012, 05:46 PM   #4
chithead
Member#: 312018
2014 WRX Hatch
Speaker wire arrived today, that makes the last piece I need to being (well, minus more sound deadener, heatshrink, and techflex).
Should be able to get started on this install pretty soon. Looking at constructing a ported enclosure, 2 cu.ft. tuned to 26hz. - right now planning on having the sub and port(s) rear facing towards the hatch.
Old 03-26-2012, 10:28 PM   #5
Paranoid Fabrications
Member#: 140712
2008 WRX STI
nice choice of items. are you planning on running two runs of 4ga wire to the back? or one 4ga?
Paranoid Fabrications is offline   Reply With Quote
Old 03-27-2012, 01:03 AM   #6
chithead
Member#: 312018
2014 WRX Hatch
I plan on just one run of 4ga to the back, and then use the extra 4ga to upgrade the underhood charging system wiring.
Old 03-27-2012, 02:10 AM   #7
chithead
Member#: 312018
2014 WRX Hatch
Finished up the radio harness a few minutes ago:
Speaker wire and RCA cables:
Old 04-04-2012, 09:46 PM   #8
luisv
Member#: 266098
2011 Outback Sport
Steel / Spark Silver
Just curious, how's the build going?
luisv is offline   Reply With Quote
Old 04-06-2012, 02:27 AM   #9
chithead
Member#: 312018
2014 WRX Hatch
Scrapped it. Decided to put it all into my 1979 Corolla.
WTB : 2002 - 2007 Subaru WRX Wagon Roof Rail Delete Mouldings imppu2001wrx Private 'Wanted' Classifieds 2 06-04-2012 01:10 PM
FS : 2007 Subaru WRX Wagon andyman1080 NWIC Private Classifieds 11 02-07-2012 09:55 PM
2007 Subaru WRX TR - 30k Miles spotted for sale at faulker subaru in harrisburg frostedjynx Mid Atlantic Impreza Club -- MAIC 7 03-25-2010 10:48 AM
FS: 2007 Subaru WRX Transmission - Pkg (RearDiff, DriveLine, Axles, etc) - $1,900 obo OregonRS-Dude NWIC Private Classifieds 5 02-15-2010 03:56 AM
FS: 2007 Subaru WRX TR - WRB - 10,900 miles dphoenix NWIC Private Classifieds 6 04-22-2008 08:47 PM
