Old 03-25-2012, 03:12 PM   #1
2012subisport
Member#: 310024
2012 Impreza Sport
Marine Blue Pearl
Default Under seat sub for 2012 Sport......what fits?
After finally getting my car, I think if I am going to do a sub I need to put it under either the driver or passenger seat. I just don't see anywhere else to put it without it being in the way. 2012 Sport 5 door. Anyone have any info on under seat subs that will fit? Thanks!!!
2012subisport is offline   Reply With Quote
Old 03-25-2012, 03:21 PM   #2
Audio Integrations
Member#: 110224
2005 WRX Sedan
PDX Tuned 295 hp 265 tq
How much room do you have available then?
If you're set on going under the seat I would build a "mock" enclosure outta cardboard as big as possible, just make sure everything clears in all seat movements/positions.
Once you have that figured you can calculate the largest amount of airspace and depth available and narrow down your sub selection from there.
Audio Integrations is offline   Reply With Quote
Old 03-25-2012, 03:34 PM   #3
2012subisport
Member#: 310024
2012 Impreza Sport
Marine Blue Pearl
I think I would like something like the earlier year Imprezas had that just bolts to the seat track. I don't need overpowering, just a little thump.
Old 03-25-2012, 03:39 PM   #4
Audio Integrations
Member#: 110224
2005 WRX Sedan
Well as far as I know nobody currently has an enclosure like this in actual production and I'm guessing the older versions wouldn't work/fit exactly in the newer 08's+ if you did locate one.
I think your only bet is to build it yourself if something is possible, some R&D on your end will be needed just to figure what is possible for what you're looking for.
Old 03-25-2012, 08:08 PM   #5
2012subisport
Member#: 310024
2012 Impreza Sport
Marine Blue Pearl
I sent an email to Subaru on line parts as they show a under seat sub for previous years to see if they have any information. Maybe they have tried it with a newer model but just haven't put it together yet. The other thing I may do is a couple of good woofers in the rear door and components in the front doors and see if it will give me some decent base. I don't need a lot, just a little thump!
Old 03-26-2012, 12:25 PM   #6
2012subisport
Member#: 310024
2012 Impreza Sport
Marine Blue Pearl
Unfortunately I received an email back from Subaru on line parts that they do not think their under seat sub will work with the 2012 Impreza Sport. Back to the drawing board.........
Old 03-26-2012, 01:57 PM   #7
achilles224
Member#: 286465
'08 WRX SSM
'02 WRX WRB
If you want a little thump, get one of these:
http://www.crutchfield.com/p_575R1L1...10.html?tp=112
and a small mono channel amp. You'll be about 1000x better off than a oem subwoofer.
achilles224 is offline   Reply With Quote
Old 03-26-2012, 02:22 PM   #8
2012subisport
Member#: 310024
2012 Impreza Sport
Marine Blue Pearl
Like that's going to fit under the seat
Old 03-26-2012, 02:41 PM   #9
achilles224
Member#: 286465
'08 WRX SSM
'02 WRX WRB
Definitely not, but it's really small (i can fit 3 golf bags in the trunk with it), and if you need to pull it out, it's really light.
Old 03-26-2012, 02:51 PM   #10
phenryiv1
Member#: 91212
2011 WRX 5DR
Satin White Pearl
phenryiv1 is offline   Reply With Quote
Old 03-26-2012, 03:01 PM   #11
2012subisport
Member#: 310024
2012 Impreza Sport
Marine Blue Pearl
I might have a better idea. See my post regarding rear door woofers.
Old 03-26-2012, 06:39 PM   #12
2012subisport
Member#: 310024
2012 Impreza Sport
Marine Blue Pearl
Has anyone tried to fit this one under the driver or passenger seat of a 2012 Sport Premium: http://www.crutchfield.com/p_777B8PT...PT.html?tp=114
If so, how do you like it and did you block off the under seat vents?
Old 04-01-2012, 09:36 AM   #13
raptorchris
Member#: 314598
2012 Impreza Sport
dark grey
Going by their measurements, it should fit under the drivers seat. I have not looked under the passenger seat. I am putting an amp under my drivers seat, and if if i remember correctly, that will work. I would block off the vent.
raptorchris is offline   Reply With Quote
Old 04-01-2012, 12:28 PM   #14
dorkbert
Member#: 309901
2012 Impreza 2.0i 5D
perhaps build your own with shallow mount subs?
dorkbert is offline   Reply With Quote
Old 08-02-2012, 03:37 AM   #15
p.allen.mariottini
Member#: 326784
Default Fits under my 2012 Sport Limited passenger seat and...
http://www.focal.com/en/car-audio-so...rs/ibus-20.php
Replaced all the stock speakers: 6 total with Focal IS & IC 165's, and added a Focal iBus 20 powered sub under the passenger seat, and an Alpine 45W Amp behind the stock head unit. Sounds so much better and didn't loose any storage space.
p.allen.mariottini is offline   Reply With Quote
Old 08-03-2012, 02:39 AM   #16
Lacessit
Member#: 311443
'12 2.0i 5DR DGM
'06 s2000
Fits great under my passenger seat. Doesn't even need to be "secured" as the seat keeps it from sliding around. PLENTY of base for the stock speakers w/an aftermarket HU (I'm running a Kenwood ddx719.
Lacessit is offline   Reply With Quote
Old 08-03-2012, 07:20 AM   #17
MtnXfreeride
Member#: 228010
2012 WRX Prem Hatch
Dark Gray Metalic
As a reccomendation..
If this fits: http://www.crutchfield.com/p_777B8PT...PT.html?tp=114
Do it (that is if underseat woofers are your only option).
MtnXfreeride is offline   Reply With Quote
Old 08-04-2012, 12:39 PM   #18
Tommy Di Cat
Member#: 146848
2012 Wrx
Even though mine is a Wrx, this might work or you. http://www.kicker.com/hideaway. Here's mine on the seat back.
Tommy Di Cat is offline   Reply With Quote
Old 08-05-2012, 12:35 AM   #19
projectsubaru
Member#: 318670
2000 OBS
SRP
how do you like the sound out of that kicker hide away?
projectsubaru is offline   Reply With Quote
Old 08-05-2012, 09:16 AM   #20
Tommy Di Cat
Member#: 146848
2012 Wrx
It works pretty well for just an 8 inch. It will fill in the bass and give a little drop. It lacks a subsonic filter that's probably the only fault I see.
Old 08-05-2012, 12:41 PM   #21
projectsubaru
Member#: 318670
2000 OBS
SRP
thanks for the input, I've been trying to justify spending the extra hundred on it over the comparable sound ordnance 8" sub, so far i've been struggling to do so..
here are the two I've been lookin at, anyone have any other input or experience?
http://www.crutchfield.com/App/Produ...&hidesimilar=y
Old 08-05-2012, 05:45 PM   #22
Tommy Di Cat
Member#: 146848
2012 Wrx
In all fairness I got it for $111 shipped. So I would've probably gone with the sound ordinance too.
Old 08-06-2012, 03:01 AM   #23
projectsubaru
Member#: 318670
2000 OBS
SRP
oh nice, wayyy jealous haha looking like i'll probably be going the sound ordinance direction too. really good reviews on it and not a huge difference in freq. response.... thanks for the help and sorry for high jacking the thread a bit haha
Old 08-06-2012, 10:58 PM   #24
wrxfan777
Member#: 328347
there are some kenwood subs out that are super slim made for pick up trucks look into that im not sure how much clearance you have but it might work
wrxfan777 is offline   Reply With Quote
Old 10-12-2012, 05:01 PM   #25
boogz
Member#: 334919
I just picked up a 2013 Sport Premium and definitely need to do something about the stock sound. It's pretty bad, IMO. Out of curiosity, how much did this setup set you back ?
The kicker hideway away looks awesome! If i wanted to use the stock speakers and radio, would I need to purchase anything additional in order to complement the addition of the kicker hideaway ? I'm far from a sound engineer and don't plan on doing the work myself, but the more info the better. My first option is under the seat, since I plan on folding those back seats down often for plywood, sheetrock and a ton of other things yet to be determined.
Boogz.
boogz is offline   Reply With Quote
WTB : WTB: Under seat sub for 2004 wrx jakeheerema Private 'Wanted' Classifieds 2 10-23-2011 01:31 PM
looking for under seat sub for 00-04 legacy/baja lgkahn NESIC Private Classifieds 1 10-01-2007 12:24 PM
Northern VA WTB: OEM under seat sub and harness for 05 STI 2005wrbluesti Private 'Wanted' Classifieds 2 12-13-2006 09:53 AM
Anyone have factory under seat sub for sale. soundspeed Vancouver Impreza Club Forum -- VIC 0 08-05-2005 12:07 PM
under the seat sub for my '00 RS. Imhotep Car Audio, Video & Security 1 01-18-2003 03:26 AM
