Go Back   NASIOC > NASIOC Subaru Models > BRZ Forum
Old 03-25-2012, 04:47 PM   #1
tad_07
Member#: 235873
04 GD, BRZ & 62Bug
JBP, CBS & Blue
Default EJ25 has already been swapped
Scion Racing | Drift | GReddy Racing
They are using a Cosworth CS600 EJ25 (~$11,000) but its still just an EJ25. Happen to have a fully built EJ257 sitting on the engine stand in my house I was planning on using in a 2dr impreza but sure would be nice in my BRZ....that will have to wait until the warrenty runs out though.
tad_07 is offline   Reply With Quote
Old 03-25-2012, 06:33 PM   #2
spaceywilly
Member#: 174268
2002 WRX, 2013 BRZ
Speedhunters did a pretty thorough article on the UP Garage BRZ with an EJ257 swap. It apparently doesn't fit the stock transmission so they used a modified STI dogbox and some pretty extensive fabrication to the frame. Doesn't look like it will be an easy swap.
spaceywilly is offline   Reply With Quote
Old 03-26-2012, 12:40 AM   #3
shirokuma
Member#: 5489
2013 FR-S
AVO Orange
We fit it to the Up Garage/Droo-P car a few weeks ago. There's not really any extensive fabrication to the frame, but then, the entire engine bay was gutted of the normal wiring harness/accessories, then we shoe-horned the ej25 in. So not exactly like you'd be simply swapping the motor in, no.
The standard gearbox in the BRZ/FR-S uses a different bellhousing than the ej25, plus the starter motor is swapped to the other side. Seriously, you won't see a lot of easy swaps of ej25's in the BRZ/FRS in the future, that's why we are working on turbo kits for the current motor that's in it.
Regards,
Paul Hansen
shirokuma is offline   Reply With Quote
Old 03-27-2012, 08:24 PM   #4
tad_07
Member#: 235873
04 GD, BRZ & 62Bug
JBP, CBS & Blue
I didn't believe it would be a direct swap at all since the FA physically smaller than EJ's are. Was hoping that the ej would bolt up though. Oh well, if I ever do a swap it looks like it will get an american v8.
Old 04-03-2012, 03:40 PM   #5
BugeyeGroceryGetter
Member#: 225067
2004 Forester XT
Platinum Silver Metallic
Did you see the ISF powered GT86?
BugeyeGroceryGetter is offline   Reply With Quote
Old 04-04-2012, 09:33 PM   #6
UKscooby
Member#: 33287
RIP Nik
I will always miss you
EJ's wont bolt up because it dosent have a Subaru transmission. It uses a Lexus IS tranny.
Someone will end up making a new bell housing that will allow an EJ to fit easily.
UKscooby is offline   Reply With Quote
Old 04-05-2012, 03:10 PM   #7
Shiz36
Member#: 147730
2007 Impreza 2.5i SE
Urban Gray Metallic
Well that explains why Modified Magazine just posted this claiming a V8 from an ISF is under the hood. No engine shots though .
http://www.facebook.com/photo.php?fbid=10151448375720058&set=a.21923233005 7.282567.119562450057&type=1&theater
Shiz36 is offline   Reply With Quote
Old 04-05-2012, 03:52 PM   #8
Calamity Jesus
Member#: 44501
1984 "Skeletor from
"He-Man"
Old 04-07-2012, 07:56 PM   #9
tad_07
Member#: 235873
04 GD, BRZ & 62Bug
JBP, CBS & Blue
Shouldn't need an entire bell housing just an adapter plate (or bell housing milled and adapter plate). Personally if it got an EJ I'd prefer the impreza sti 6spd with it, remove the front diff. and add a block off plate where the axles go in and bam a 6spd with a little more top end. (STI 3.90 FD vs BRZ 4.10 FD) Plus a STI 6spd in known to be good for ~500awhp so it should be good to go. Stock EJ257 with a tune and stg2 mods is 300awhp, add a little for rwd vs awd and the brz would have decent power.
Old 04-07-2012, 11:20 PM   #10
Calamity Jesus
Member#: 44501
1984 "Skeletor from
"He-Man"
Uhhh.. think about that a little harder.
And if you're going to swap out the whole drivetrain, why play around with Subaru parts at all?
Old 04-08-2012, 03:52 AM   #11
tad_07
Member#: 235873
04 GD, BRZ & 62Bug
JBP, CBS & Blue
I was simply saying if you wanted to do a swap and keep it subaru then to me that would be the way to go. That is also only part of the drivetrain
You could have look at my other post
... if I ever do a swap it looks like it will get an american v8.
Would be nice if with some tuning on the fa20 ~250whp and 200ftlbs could be acheived at a decent price.
Since a religion thread has already been locked... OriginalSin Off-Topic 19 09-26-2005 09:44 AM
Has this already been brought up?? Skell Off-Topic 19 03-20-2005 02:38 AM
Has Bin Laden already been captured? del105 Political Playground 66 10-12-2004 08:51 AM
$10 says this Ebay item has already been posted Stroke Off-Topic 24 04-07-2004 02:54 AM
I'm sure this has already been posted... JC General Forum Archive 5 10-20-2000 05:52 PM
Message Board Statistics All times are GMT -4. The time now is 01:03 AM.
