Old 03-25-2012, 03:12 PM   #1
teefivetee
Member#: 296046
2005 sti
Default Coolant Bubbles Nonsense
Just bled my coolant system for prolyl the 3rd time....
im still having bubbles pop up in my overflow bottle still, not like boiling, just a bubble here and there...and its not even every time, jsut maybe every other 2 drives if that..
my arousing suspicion is the HG, but im hoping its not that..im not overheating, no white smoke or water out the exhuast....literally no other symptomsbut that.
my coolant level has stayed the same thoughout all of this, within the overgflow/rad etc... hasnt gone up, nor lowered...
am i just being paranoid about a HG...id figure id have more issues..ie:less power, and overheating etc if it was that...
any ideas guys? any help is MUCH appreciated...
thanks
oh, did a block test and it came back negative..
teefivetee is offline   Reply With Quote
Old 03-25-2012, 05:50 PM   #2
Rally Monkey
Member#: 36310
03 WRX Sedan
I think you are being paranoid, if there was air in the system, coming from the head gasket or just in the system at all, it would affect the block test. You bled it correctly, so don't worry.
Rally Monkey is offline   Reply With Quote
Old 03-25-2012, 05:58 PM   #3
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
did ya replace the CAP??
Old 03-25-2012, 07:07 PM   #4
teefivetee
Member#: 296046
2005 sti
i did, i replaced it with another OEM subaru cap when i did the water pump, im beginning not to feel so paranoid, as to its not bubbling on every run now, figured the HG would be all the time, as i watched some videos online and mine nevr looked anything like theirs.
thanks
Old 03-25-2012, 07:26 PM   #5
Rally Monkey
Member#: 36310
03 WRX Sedan
This guy just seemed thorough.....Black Sabbath......
Old 03-25-2012, 07:27 PM   #6
teefivetee
Member#: 296046
2005 sti
lol what...
Old 03-25-2012, 07:33 PM   #7
Rally Monkey
Member#: 36310
03 WRX Sedan
Paranoid.....Black Sabbbath.....You seemed to be aware of detail is all....
Adding your car info to your name...helps too.
Old 03-25-2012, 07:53 PM   #8
teefivetee
Member#: 296046
2005 sti
Add your car info to name...help too.
ah yeah, ive just had so many issues when i first got the car i was just paranoid at this point, figured it had to be air since my car never did this till after i did the water pump
thanks again, and shall do
Bubbles in coolant? mr2quick Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-03-2008 11:38 AM
bubbling from coolant resevoir TUNERwRX Built Motor Discussion 14 10-29-2008 12:24 AM
Coolant leaking around radiator cap bubbles inside Ostrowrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 10-08-2008 10:48 PM
Coolant smell/ bubbling elohdaeh78 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-26-2008 01:02 PM
burb the coolant on 02 wrx.. air bubble dvang Service & Maintenance 3 08-05-2005 10:19 PM
